Can anyone tell me which model works on the 02 VFR? The standard "honda" model specs dual cables. I see only one cable on the 02 throttle. Thanks. Paul
It's dual cable system. You will need to file the unit a little thinner in the center hole so that it does not hang up the throttle. Unless you have Gen Mar, or Helibars, you will also need to file the thumb switch so that it does not contact the tank on full lock.
