Voltage meter install with pics
Discussion in '5th Generation 1998-2001' started by TNRabbit, Jun 9, 2014.
  1. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Finally got around to installing the El Cheapo voltage meter I bought back in May (amazon.com, @ $8).
    I didn't want to be staring at the light, especially at night, so I hid it behind the left handlebar. I used Dremel and utility knife to cut/shape the hole. Took about 30 minutes. Wiring was run along the frame directly to the battery; plan to install a switch later.
    I'll upload a video later.
  2. Scubalong
    Nicely done, now make sure put some silicon to water proof the unit.
  3. ridervfr
    Belgium
    Nice straight cut, no biers :drinkers: You go to the battery terminals with the connections? two wire/?
  4. TNRabbit
    TNRabbit New Member
    Woodford, VA
    It is a waterproof meter.
    Yep, 2 wire straight to the battery. Guess I'd better fuse it, huh?!?
  5. ridervfr
    Belgium
    It would be a prudent thing to do. My radar was fused when I ran it directly to the battery, keep your local radio shack in biz. :loco:
  6. blainerides
    blainerides New Member
    Seattle, Washington, United States
    Your link for the unit you purchased "just" went to the main Amazon front page. Do you have a link for the actual unit you purchased?
  7. mello dude
    Nice job!
  8. TNRabbit
    TNRabbit New Member
    Woodford, VA
  9. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
    I ran mine through a relay as well so that it switches on when the ignition switch is "on"
  10. ridervfr
    Belgium
    relay makes sense. ^ ur a genius or something like that :homer:
  11. mello dude
    I've seen a lot of guys do that. I just wired it with a separate switch so I can check battery voltage before start up. It helps with no surprises later.
  12. Dead Eye Dick AKA Carpy
    Chill Out City
    Going via a relay means the voltmeter is running in the background. If things start to go pear shaped with the charging system when you are on a ride you would be able to see the charging voltage dropping as it happens.
  13. VFR Love
    VFR Love New Member
    New York
    What should voltage be? I have to correct mine which is tapped off the headlight.
    It fluctuates depending on if I'm running high beam, heated grips, what RPM I'm at, etc.
  14. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Voltage should be between 13.8 & 14.5 when charging. It will fluctuate depending on RPM, & load when not runnning. Probably less at idle, but that's OK provided it picks up above 1500 rpm.
  15. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Nice work.
  16. VFR Love
    VFR Love New Member
    New York
    I'm always seeing 12.7-13.1
    Meter might be off.
    Or could it be because it's tapped off the headlight?
  17. Mrboss
    Mrboss New Member
    São Martinho Do Bispo, Coimbra, Portugal, Portuga
  18. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Video as promised. It always starts out in the 13s but climbs to around 14.3/14.4 & stays there when I ride.
    [video=youtube_share;hmdys94FPoQ]http://youtu.be/hmdys94FPoQ[/video]
  19. TNRabbit
    TNRabbit New Member
    Woodford, VA
    Verified it is indeed waterproof today...unlike my crappy walmart Frog Toggs rain gear~
  20. GarrettSR5
    GarrettSR5 New Member
    That's pretty trick.
