VTR 2fiddy parts bike
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Oct 22, 2025.
  1. squirrelman
    1465113266_010_10a.jpg.d831dd79ceadb55adb36eaa8e765f50a.jpg stock jetting wont be best if youre not running original exhaust, too lean--inspect the air intake to te airbox tube to be sure that part of it is not blocked off--i believe i ran a dynojet kit on one of my vtrs not sure which
  2. RogueRC24
    Stock everything to continue clarifying. Lol. Sorry.
    I should get a manual later this week. Part of the free gear in SoCal. The guy found a title for the frame and service manual and mailed it fo free.
    Float height if anyone has easy access or I can wait until later this week.
  3. RogueRC24
    WTF Honda? Put in a fuel cross tube, but blanked off the front carb connection. Lemme guess….Kalifornia.
    pictured is the fuel cross tube Y, front fuel fill on the upper right, original fuel hose Y, and the blanked off large hole.
  4. squirrelman
    fs_6992.jpg id suggest u replace those O-rings :oops: float height 9mm---------------------- nov3-21 015.JPG
  5. sixdog
    No comment…
  6. RogueRC24
    Ahh thanks SM! 9mm for both it will be. I replaced the fuel T, pilot needle, and bowl drain O-rings from my stash. I need the bowl gasket at this point. Leakdown will provide more info. But tonight is bowl gasket order night. :)
  7. RogueRC24
    DeKalification. See plugging questions in photos? I was going to plug them all together.
    88FBCE7B-FF49-4889-B058-540DD9B80C3B.jpeg D97CC68E-01A6-4BAC-A5FD-7783C73AB424.jpeg
  8. squirrelman
    yes, plug the tubes---the clear lines may not be safety- rated for fuel, not safe maybe ? will get brittle and could crack after some time -----------------------------------------------------------------------------------------------------------------------please dont ask me about a customer's yamaha V-something 950 that started burning :Flame::Flame: under me on a test ride in around 1998---back when i worked at a shop :eek:---glad it wasnt a honda--- total loss and my shoe was burning before i stepped off
  9. RogueRC24
    oh dang! Those are tygon, supposedly rated for fuel hoses (the yellow). Thanks again SM!
  10. squirrelman
    hey wait a minit, i might be totally wrong about the clear tubes o_O
  11. RogueRC24
    New problem to me. Trying to remove lower fork bolt and the bolt and assembly would rotate with the drill bit. Spring did not provide enough pressure to hold the parts in place. So my wife pressed our 2.5’ breaker bar into the assembly minus the spring and spacers. Worked like a charm, but I had not come across this before. Still learning shit! Bolt head removed. image.jpg
    The ones you are asking about are both vacuum and need to be "plugged". But when I have two that need to be taken care of, I connect them with good vacuum line. I trust it over time/heat more than a plug.
    EDIT: You have three vacuum apparently. I would connect the two with the bent spigots and plug the straight one.
    Re forks: Right when I was about to remove the forks from the 90 for disassembly, I thought, "WAIT!" I reinstalled the fender as it has a built in "fork brace" to isolate the lowers and I tried the lower bolts. They both released like a drain plug. It was glorious.
    I've had to drill quite a few. It doesn't even bother me anymore. The bottom of the hex area is shaped for the perfect center start and you can't really damage anything.
    Good job.
  13. RogueRC24
    Thanks for the input dude!
    Vacuum- got it.
    Question, Squirrel said 9mm on float height. The '88 service manual says 6.5mm. This is not an '88, but the carbs may be. Should I just cut the distance in half and go?
    Unfortunately, the second fork is doing the same thing so my wife will need to help me tomorrow. :)
    I am jealous of your "drain plug" glory! hahaha
    Cheers, Capt!
    Anytime a spigot exits the carbs right above where they engage the intake boots, it's gonna be vacuum. That's how they are creating vacuum, by using the high velocity air flow. Just like using a compressed air nozzle across the end of a tube to start a siphon.
    I am definitely not saying to go against sm's advice. 6.5 and 9.0 are a ways away from each other. Perhaps try and verify which carbs you have by the serial numbers. The Factory Service Manual should list the Serial #s for the 88 carbs.
    Disclaimer: THIS IS NOT A POLITICAL STATEMENT OR A DECLARATION OF PARTY AFFILIATION. I just always liked the quote.
  15. RogueRC24
    Still learning. I did not realize that carbs are serialized. Back to school! Thanks again! I like Reagan, I dressed as him for Halloween (See Point Break). hahaha
  16. squirrelman
    GEEEZE, man !!:oops: i gave u the WRONG 411, so sorry, im em-bare -assed /////// CORRECT float setting is 6point8, not 9mm (hawk) what i wus thinkin :confused:,,,,,,,,,,,,,,,, april 3-----2026 094.JPG
  17. RogueRC24
    All good bro ham. I just wanted to to put that out there since the ‘88 manual arrived and gave those dims.
    Back to forks. 4 hrs of tearing down and cleaning 4 forks. Seemed endless. But they are ready for rebuild now. ‘88 chrome and damper parts with ‘90 lowers to accommodate a real rotor. Paint is meh, but not bad enough to warrant strip and re-paint.
    Stoked overall.
  18. squirrelman
    aug 1 2020 018.JPG can u get new stickers for the lowers, a part # maybe ? mine need serious refinishing and paint, which i wont get around to :eek:
  19. RogueRC24
    Why would someone want stickers on their forks, like a chain guard, sm? So everybody thinks he needs to check what kind of forks he has?
    "Haha, u got stpd stikrz on ur ferks!" And then he crashes and cries.
    jus bustin ballz, u know i lov u ;-)
