VTR 2fiddy parts bike
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Oct 22, 2025.
  1. RogueRC24
    image.jpg Thanks boyz!
    The only reason I took this bike (besides VFRW harassment) was it was a Honda. I have now seen shit rise from the ashes like nothing else. 8 Hondas and 1 air cooled Duc. No more ducs and only Hondas. :)
    Does anyone recognize this plastic cover? Can’t find an image of my own or in the service manual. Kinda maybe to do with the coils, but didn’t seem to fit entirely. Roughly 5” x 3” with 1 mount hole.
    And a Fender pic of porn reasons.
    I have two VTRs disassembled right now, one 88 completely and one 90 starting to get big again.
    I do not recognize that part at all.
  3. sixdog
    It’s a thing-a-magigy!
    Crap
    Maybe a battery cover ? Under the tank cover ?
    COVER, IGNITION COIL
    30406-KV0-000
  5. sixdog
    Boom!
  6. RogueRC24
    image.jpg image.jpg Thanks again!
    ahh ha! Found a partial image in the manual. Looks more like a heat shield for its usage.
  7. RogueRC24
    For clarification.
    Nice
  9. squirrelman
    thats the factory tool kit pouch cover that slides into place in its recess behind the battery 87a2.jpg
  10. RogueRC24
    62971C4A-2768-4771-9107-92CE114AFB12.jpeg 3144BF84-7206-4EE9-B229-D0A46A9D20C9.jpeg Getting there. Did some metal fuel tank sealing. Had 20+ pin holes. JB weld metal fuel tank repair in place. Basically metal infused JB+ fiberglass. I will then go to heat shield material for the final step. It looks like poo, but it was curing so fast I could barely keep up. Tomorrow I can test sealing of the tank.
    The powder coat coat came out nice! I think the color is as close as we could get. RAL 5002 Nordic Blue.
  11. RogueRC24
    12 hours past the cure time and we are testing for leaks. So far so good. 1.5 gallons of isopropyl alcohol.
    Captain 80s likes this.
    Are you going to seal the inside?
  13. squirrelman
    caswell works great
  14. RogueRC24
    I was not going to. I will let the new owner decide.
    I did place some heat shielding over the epoxy to keep the temp down and look slightly better.
  15. RogueRC24
    And I was a dumbass on the petcock. I cleaned it real well and put it together properly and it seems to work great! First time my Mighty Vac actually helped. Lol
    Which is good because my eBay petcock is crap. Leaks from the switch seal.. thanks China. Oh and that little plastic guard near the coil is redirecting leaking fuel.. go Honda! image.jpg
    The repair WILL fail eventually. In about 2 or 3 years.
    I did a similar repair on a SL100 tank. Now I will be sealing it with Caswell.
  17. RogueRC24
    Ok too many fumes. You must place the fuel tank rubbers correctly to align the petcock into the frame. Should be centered. The side loading was causing the petcock was leak when the lever selector was not centered. Make sense… the fumes! Lol
  18. RogueRC24
    As part of my “ needs attention “ report I am listing professionally sealing the inside of the tank. Along with tires and brake lines.
  19. RogueRC24
    Running off the fuel tank now! Time for a super ginger drive way test ride. These tires are oooooold.
    good and bad. She runs great and scooots as one would expect.
    bad, I think the front fairing stay is bent slightly so the bodywork won’t line up. Next weeks project.
  20. sixdog
    Looks beast brother!!!
