VTR 2fiddy parts bike
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Oct 22, 2025.
  1. RogueRC24
    First bath in roughly 20 yrs. Pulled plugs, sprayed lube on the valves, pulled the timing cover and see if the engine spins.
    No stick and rotates freely! Enough compression to push the plugs up a little.
    Can I do a compression check while turning the bike over by hand? image.jpg image.jpg image.jpg image.jpg
  2. bmart
    bmart Member
    Charlotte, NC
    There one of the most visually pleasing bikes made...to my eyes. Same as the FJ. Congrats. I'm envious.
  3. RogueRC24
    Wow, she cleaned up real nice. Mostly undamaged bodywork on these bikes is RARE.
    The white tank is odd (as in not stock), but I like it.
    This cap is exactly like the cap in my VTR. There's another listing that shows the OD measurement and it is identical.
    https://www.ebay.com/itm/376028547078?_trkparms=amclksrc=ITM&aid=777008&algo=PERSONAL.TOPIC&ao=1&asc=20250417133020&meid=83e9cf16229f44b38b5c572cfef52991&pid=102726&rk=1&rkt=1&itm=376028547078&pmt=1&noa=1&pg=4375194&algv=RecentlyViewedItemsV2WithMLRPboosterAndUpdatedFeatures_BP&brand=Unbranded&_trksid=p4375194.c102726.m162918
  5. squirrelman
    following closely cuz i love the 250, the only bike in my garage im riding now.
    RogueRC24 likes this.
  6. RogueRC24
    Alright, gave the bodywork an initial cleaning and fitment check. So far so good. I will check compression shortly. image.jpg image.jpg image.jpg
    squirrelman and sixdog like this.
  7. RogueRC24
    Sweet!! This link worked ( https://www.ebay.com/itm/376028547078? ). Thanks Capt!!
    I tried to check compression, but it will only go to 60. It holds, but I a total newb on what makes a compression test work. I had no plugs in and no carbs on, turning by hand.
    I hope there is a better way or some config I am missing. I went from "hey maybe I can sell the bodywork" to "hey if it runs I may keep it". hahaha
    I really am a sucker for white wheels and I love the single floating rotor look. Cool little bike.
    The key for the ignition does not work on the helmet/seat lock so that is a bummer. I removed the locking mech so I don't accidentally lock the seat on.
    Look forward to compression input. Have a good Sat night!
    You have to crank it at speed. With a helper, you can put battery voltage from a car battery directly to the starter. Throttle WIDE OPEN.
    Or jump to the battery leads so you can use the ignition and starter button.
  9. RogueRC24
    I can't do throttle wide open, there are no carbs. So, it sounds like no need to find carbs first or put in the other spark plug, just turn it faster?
    No carbs = throttle wide open. But you do need to spin it up. The other cylinder (without a plug) doesn't affect the one your testing.
    You might squirt a little oil in the cylinders and hand crank for a bit before spinning it up. Same goes for the cams. With the carbs out is a good time to pull some covers. Plus you can check out the cam condition.
  11. RogueRC24
    Awesome info. Unfortunately (maybe) we are trying to prep for Japan this week, and I couldn't make time to get to it. Possibly Wednesday evening. :)
    Captain 80s likes this.
    Fixed it for ya?
  13. RogueRC24
    Nah man, my son is sitting on NSR parts for me!! lol
    Confused. Was trying to say prepping for Japan is a good thing. Riiiiiight?
  15. RogueRC24
    All good. I am looking forward to a new Arai helmet and riding gear from Japan. We will also be visiting some "used shops" while in town. See if I can find some diamonds in the rough. Upgarage is the company. They are like goodwill for moto parts. haha
    bmart likes this.
  16. squirrelman
    expecting photos of shops there please. see if you can find some '86/'87 seat cowls with pads and bolts for the boys back home.
  17. RogueRC24
    I will be looking. I still need one.. lol
    they use the VFR800 and bigger for cop bikes.
  18. RogueRC24
    We have lighting!
    Cams:
  19. RogueRC24
    front
    bmart likes this.
  20. RogueRC24
    I ran the front a little longer but I think they are both about 200psi. Yay
    I added a little oil down the spark plug hole and kinda sprayed over the cams, chain and a littl below. I figured more wouldn’t hurt. Hahaha
