VTR 2fiddy parts bike
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Oct 22, 2025.
    #81
    RogueRC24 and bmart like this.
  2. Jim McCulloch
    Jim McCulloch Member
    Subscribed
    #82
    RogueRC24 likes this.
  3. RogueRC24
    Valve lash set. Resprayed covers. All of the valves were tight.. glad I looked. Must be a first service kind of thing, that never got done? image.jpg
    #83
    Jim McCulloch and Captain 80s like this.
  4. RogueRC24
    A little progress. Resprayed the plate mount and seat lock.
    A small snag. I only have the ignition key but it does not work for the seat lock. Anyone have a key and seat lock?
    #84
    bmart likes this.
  5. RogueRC24
    Oh and I always wondered but know I know what OKI on Factory Hondas is for.
    #85
    Remove the break-off bolts and get the key number off the lock/latch.
    If you have some nice fresh vise grips, they will pop loose pretty damn easy.
    I think I have only had to lefty-loosy with a chisel one time.
    #86
    Where did they find a 17" wheel barrow tire for the rear? Jesus.
    #87
    bmart likes this.
  8. RogueRC24
    Oh no, it has amazing grip value on the dirt in the barn from whence it came!
    #88
  9. RogueRC24
    Sweet, thanks! They are threaded and I twist or literally break them off?
    I tried using the flash light at every angle but could not see a thing. Sounds like a next weekend proj.
    Still waiting for my gaskes and whatnot.
    #89
  10. RogueRC24
    OKI and Okidata refer to the same brand of printers, with "Okidata" historically used by the American subsidiary of Japan's Oki Electric Industry Co., Ltd. Known for durable dot-matrix and LED laser printers, the brand stopped selling new hardware in the Americas in 2021, but continues to support, service, and supply consumables for existing, highly-regarded professional machines.
    In case you wanted more! Doohan and Gardner bike for Suzuka 8hrs, 1991. RC45
    #90
    When they are installed new, they have a narrow-waisted section that breaks off the hex head when a certain torque is reached. That way someone can't simply unbolt your helmet lock to steal your helmet and/or see your key # easily.
    You need to remove the bolt by the what is left of it. Fresh Vise-Grips usually suffice easily. I have done it dozens of times. When removed, you can read the key number. Last 3 digits, this one is "C54"
    #91
    bmart and RogueRC24 like this.
  12. RogueRC24
    Awesome! thanks!
    #92
  13. RogueRC24
    Hey look OEM Honda fluid possibly from 1990. Good start to the coolant system tear down. image.jpg
    #93
    bmart likes this.
    That is an encouraging sight.
    #94
  15. RogueRC24
    Water pump spins with crank, so no locked up badness. More cleaning and new OE gaskets going on tomorrow. 99F1DB03-157B-443E-AD61-621513DB00EF.jpeg
    #95
    Hell
    Yes
    #96
  17. RogueRC24
    In the VTR loot boxes i found the ignition and a fuel with cap on the tank, but no key. One can assume it is the same key for all. Does ONEA11 sound like a good code?
    #97
    A11 does
    #98
  19. RogueRC24
    Super bored…
    Is the loot box components.still no key. Plus main frame, wheels , rear fender, 1.39 sets of bodywork. image.jpg image.jpg image.jpg image.jpg
    #99
  20. RogueRC24
    Rebuild with best mix, then friends (here) and then eBay.
