VTR 2fiddy parts bike
Discussion in '3rd & 4th Generation 1990-1997' started by RogueRC24, Oct 22, 2025.
  1. RogueRC24
    What is all the stuff in the sight glass and can I remove it without damaging stuff? I wanted to sand blast but I don’t want to jack anything up. Ideas?
  2. Terry Smith
    For S&G I recently removed the oil glass from a spare VFR1200 clutch cover, and that was only held in with a rubber gasket and a little sealant. I was able to gently knock it inwards from the outside.
    I had forgotten that Honda used to have that dandy windscreen wiper on the inside of the oil glass. Nowadays one has to pull the clutch cover off to do any glass cleaning.
  3. RogueRC24
    Interesting. So if I turn the little screw it will clean the glass? I will have to look internally to see what kind of rubber gasket is going on. Thanks T dawg!
    bmart likes this.
  4. Terry Smith
    You betcha! Well at least it did when the engine was first assembled.
    On a bike I was trying flip, I would do ANYTHING to avoid popping that glass out. I would triple/quad up some masking tape for sand blast. Maybe even sandwich some aluminum tape in masking tape.
    RogueRC24 likes this.
  6. Terry Smith
    I was contemplating getting my "good" clutch cover powder-coated as my first attempt at a repaint was garbage (soft and rubbed off); so I was experimenting on my badly rashed cover to see how hard pulling that glass out was. I have managed to get a much more durable coating (Holts Duplicolor over an etch primer) with my second attempt so I'm no longer going that route. IMG_8449.JPG
  7. RogueRC24
    Does the clutch mechanism in the cover remove easily? It looks it on the surface, now I am second guessing myself. Silly questions. Kinda wished I hadn’t pulled it.
  8. Terry Smith
    Sure looks like it; the manual shows the lifter arm coming away with the cover, then on the inside of the cover you lift out the clutch lifter and remove a snap ring and the return spring and the shaft can slide clear.
    There is probably a pressed in roller bearing in there.
  10. RogueRC24
    Well if I am going to do it right, then I will remove the clutch actuation assembly, seal up best as possible and cover the site glass like crazy.
    Or....
    Thoughts on Jasco paint remover instead of sand blast? Might take way longer, but time is on my side since I am out for a bit. Maybe in a couple weeks I can get both hands on it. :)
    Honda crankcase cover and wheel paint is very resilient shit.
    I've used stripper on both and still had a lot of work to do. I had to actually finish some 86 valve covers in the sand blast cabinet, but I don't think the black is as difficult.
    Just don't expect it to melt away and then rinse with a hose (probably).
  12. RogueRC24
    Yeah, I experienced the lack of melting away on another Honda. Just made a mess, when I could just blasted it. Thanks!
  13. RogueRC24
    Figures, that the free harness with ignition is not the same key as the helmet or fuel cap locks. Wtf.
    Going with the Capt recommendation for break off bolt removal, I pulled the helmet lock apart. That method works great! Thanks Capt!
    Time to order another key.
    It's way easier than it seems. They do not have much torque when they "break".
    BAM!
  15. RogueRC24
    Ordered another key with the code off of this lock. Hopefully it matches the tank filler as well. I could really use that cap. Not much more I can do at this time, but at least I got another little item done and learned.
    Captain 80s and sixdog like this.
    Pretty cheap exploratory mission. Get some!
  17. SanDogDewey
    SanDogDewey New Member
    When you say sandblast, I hope you mean soda blast.
  18. RogueRC24
    I have been sand blasting most aluminum pieces followed by a a sonic bath, alcohol soak, primer and paint with clear. Cheap but effective. Red has been that way for over 4yrs and still looks good.
  19. SanDogDewey
    What media are you blasting with. Doesn’t it pit the aluminum?
    I use sand on crankcase covers too. Followed with thorough cleaning. We are not talking about actual crankcases.
    I'm not sure how effective soda would be against Honda cover paint. But I don't know.
    I also don't want to have 2 cabinets or switch back and forth. I want/need sand 99% of the time.
