Weird clutch "grabbing" on 2000 VFR
Discussion in '5th Generation 1998-2001' started by 0dder0tter, Nov 29, 2015.
  1. JimHanus
    JimHanus New Member
    Push rod is clean and smooth. I just bled the clutch again, didn't see any bubbles. We'll see tomorrow.
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Sent from my Nexus 6 using Tapatalk
  3. JimHanus
    JimHanus New Member
    UPDATE: Tried it again today. Still grabs. I experimented with it. If I give it some throttle, about 3k rpm, and let the clutch out slightly the bike starts moving normally. Without letting the clutch out completely it will suddenly grab and jerk forward. Only does it once when cold, second or 3rd stop sign (same stop sign as last 2 times). Won't do it after that. I think tomorrow I will pull it apart and see how things look. I'll let you know.
  4. JimHanus
    JimHanus New Member
    I did some searching online for motorcycle clutch grabbing. Apparently this same symptom is pretty common (only does it cold, and on the 3rd or 4th cycle of clutch release, and only one time). Opened the cover up this morning and pulled the plates. Everything looks normal and measures within spec. Only weird thing is the plates appear almost dry. If I didn't know they were supposed to have oil on them, I would think they were new and dry. My guess is that the oil drains off them overnight and takes a while to circulate back to them. Not sure how they get oiled, if it's just from splashing of the gears or if there are oil jets or holes somewhere. Only holes in the clutch basket are all open. I read one post where the person corrected the problem by flipping the steels around (among other things) and making sure the were all facing the same way. The steel disks are stamped, and as such have one sharp edge and one slightly rounded edge. I guess that will be my next test (flipping them all the opposite way). Also, there's no notching of the clutch housing fingers, although the spring towers of the clutch hub do have some grooving. I will probably replace the clutch hub next. I'll report back tonight.
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    How much longer are you going to keep screwing around with this before you go buy a set a $15 clutch springs?
  6. JimHanus
    JimHanus New Member
    Anyone ever tell you to go fuck yourself?
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Lol sorry about your feelings bud. I posted the part number for the 99 pound barnett springs. Give them a try and if it doesn't work out I will send you some flowers and chocolate.
  8. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    Just a thought, but did you soak the disks in oil before installing them?
    I did mine in hot oil and left them overnight.
    My bike use to do that very violently when cold, so I replaced the springs and plates.
    Never did it again, done over 30000km since.
    Don't shoot the messenger mate, everyone is only trying to help.
  9. Lint
    Lint Member
    Simi Valley, Ca.
    I want to resurrect this thread to add that I have contacted Barnett and they have the 100# springs in stock,
    MT-91-5
    100# springs
    $18.00
    Barnett Tool & Engineering
    2238 Palma Dr
    Ventura, CA 93003
    Mon.-Fri. 8am-4pm (PST)
    Ph: 805-642-9435
    Fax: 805-642-9436
    I'm ordering a set after my trip. I just don't have enough time to install them before I leave.
