Weird Weird HELP!!!!!!!!!!!!
Discussion in 'General VFR Discussions' started by volmann, Dec 18, 2015.
  1. volmann
    volmann New Member
    Johnson City TN
    GE brand...hold
  2. volmann
    volmann New Member
    Johnson City TN
    None of the blades have 12v, with fuse in and neg lead of volt meter on neg side of battery, and touching each blade with pos lead
    the battery does have 12.6 volts when tested...and the cables on the relay have 12.6 ....but zero on none of the blades
  3. TOE CUTTER
    pm sent......
  4. volmann
    volmann New Member
    Johnson City TN
    0.00 on all 4 blades
  5. TOE CUTTER
    How aboot the cable connection from the battery to the relay?
  6. volmann
    volmann New Member
    Johnson City TN
    Has 12.6 volts
  7. STing
    STing New Member
    Kyle Texas
    It appears to me your jumper system is actually bypassing the ignition switch. This was a very common work around with fords when the switch went bad. Power to selonoid to open path way for 12 volt high amp power from battery to starter is from the ignition switch.
  8. volmann
    volmann New Member
    Johnson City TN
    well its fixed
    the main cables on the relay were reversed
    i just assumed the one with the B was for the battery and the one with the M was for the motor/starter
    but i reversed them and bingo it worked!
    Damn
  9. volmann
    volmann New Member
    Johnson City TN
    now something else
    everything works starts and charge
    but when u pull the clutch in to change gears the N light come on...but with side stand down the N light does not come on when u pull clutch in in gear....flip side stand up while in gear with clutch in N light comes on
  10. jev.
    jev. over there
  11. volmann
    volmann New Member
    Johnson City TN
  12. jev.
    jev. over there
    It's what is causing the neutral light to come on when you pull in the clutch. I'm not sure how, but that's what I had to do on both bikes that I had with the same issue. Someone else on here had the same issue a few months back and it fixed theirs too.
  13. volmann
    volmann New Member
    Johnson City TN
    Yup. found it..its fried
