what causes a Burnt Harness?
Discussion in 'General VFR Discussions' started by mrvfr, Oct 14, 2010.
  1. tinkerinWstuff
    :hangme: :rapture:
  2. BadRR
    BadRR Banned
    So i finally got my harness for recitfierregulator.com, im a bit dissappointed that the connectors for hte battery side of the rr didnt fit, but i got it real quick. the clip didnt work either. but its in and seems to be charging. 14.4 v across the battery.
    but again, what caused the problem in the first place. obviously the 2 stator wires shorted, the plastic was pretty hard, did it simply brake and make an non insulated area? i cannot imagine a foreign material got into it, wouldent that cause a burn at the opening, not deep inside?
    i suppose there is no real way to know for sure. im heading out of town. i just hope it keeps charging.
  3. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    All high current connectors are subject to failure from moisture-induced corrosion, particularly if they are friction-fit instead of clamp style; clamp style being a ring terminal held in place with a fastener (such as a battery terminal). Once a little bit of corrosion forms, the connection becomes a "voltage drop"; it becomes an electrical load instead of a straight electrical connection, as Singer732 pointed out. Typically, the connection that has turned into an electrical load gets hot, which in turn causes it to get more resistive, which makes it get even hotter, which makes it get more resistive, etc. I believe that part of the issue is that the metal in the connectors start deforming due to the heat, so that the friction fit that is relied upon starts loosening up. At that point, the surface area of the metal-to-metal connection is reduced, so the resistance goes up, etc, etc. It eventually gets hot enough to start melting all of the plastic surrounding the contact, which starts flowing into the contacts and making the problem even worse. Then the heat starts melting the insulation on the stator output wires.
    The stator doesn't know about an excessive electrical load; it just keeps putting out electricity. When the electrical load gets to the point that it exceeds the stator windings output capacity, the stator windings start getting hot which eventually melts the thin varnish insulation on the copper windings. Then the windings short together and create a localized load, which would pretty much be a direct short circuit. Motorcycle charging systems tend to be primitive, compared to automotive systems. They typically always run in full output mode because they use permanent magnets in the alternator; the magnets can't be 'turned off". So generally an output value is selected that will fulfill all of the requirements of the bike in addition to some reserve capacity for anticipated accessories (heated clothing, GPS, etc.). The reason the R/R is so big is that it has to handle all the heat generated from a charging system that is always in full output mode.
    FWIW, most friction fit connections are somewhat self-cleaning if they are occasionally separated and rejoined. The contacts areas drag across each other and wipe away some of the surface corrosion. However, once the plating on the metal goes away, corrosion rapidly sets in, especially in a humid environment.
    You'll see the same type of failure in a standard house receptacle, particularly in a bathroom that has a hair dryer left plugged in.
  4. reg71
    Sikeston, MO
    I was about to delete this entire thread because I realize the annoyance that 'certain" people seem to try to cause, but when I saw LGN's detailed answer, I didn't have the heart to do it. He put a lot of effort into it, and I'm sure that if I was more sober I could learn something from it. Hopefully, though, it will help someone who actually can read at this current moment so I will leave the whole damned thread up just in case someone reads the posts that pertain to the actual problem. As to the actual bunghole that keeps just posting BS to aggravate the regulars, all I can say is that...well, he's our troll and if we just feed him a little, then pet him a bit here and there, maybe we can tame him.
  5. Joey_Dude
    Joey_Dude Member
    North Georgia
    Damn you Lgn the terrorists have won!
  6. tinkerinWstuff
    I've tried that reg. When he snuck back in we traded PM's and I told him to just be normal and no one would give a shit. He got the mrvfr account to over 100posts before revealing himself with some stupid comment about a trailer. He enjoys causing trouble and he's a kid who loves to keep pushing the limits to see just how far he can get, and then do it again.
    no one had even done anything to his mrvfr account and he chose to create another new account and create more posts making sure everyone knew it was him. He's not tame-able and has no intention of playing by the rules. I don't know how many chances a guy can be given but I'm sure it's pretty clear that he won't be getting any more from me.
    For a guy who's such a loser, you think all he'd want to do is get along with people. No one here would care and he's been welcomed by many members many times. Instead he chooses to take their good will and throw it in their face. There are people who aren't around enough to see the crap he pulls and they stick up for him. I was one of those people at one time when he went by goferaride or whatever it was.
    Now I would rather punch him right square in the mouth.
  7. SilverSurferRWB
    SilverSurferRWB Member
    Bay Area, CA
    Don't you think this is the EXACT kind of reaction he's looking for? If you ignore him, he will go away or stop being such an annoyance to the general population. Stop posting in his threads, don't chat or PM with him just ignore him. He knows he's gotten under your skin so why would he stop? Take yourself to another level and move past the :bs:
  8. Lgn001
    Lgn001 Member
    The war is never over. One battle at a time...
    In the end, there will be no more terrorists; it's part of my master plan. :smile:
    Actually, I replied because it was a valid question that I could answer. Sorry, JD! I promise to control myself from this day forward. Hmm. "Promise" might be a bit too strong; I'll TRY to control myself from this day forward. :biggrin:
  9. reg71
    Sikeston, MO
    Here's the problem from my end. (I'm posting this in public because MANY of you guys have e-mailed me regarding this situation) Said user does post legit items many times, AND he also posts many annoying things apparently just trying to aggravate. He has been e-mailed several times before EVER getting close to being banned. You guys know how lax we are about banning here. Even though VFRworld IS NOT a public site, we are pretty liberal about what you do and post. We mostly let you guys handle it on your own. The only pretty much automatically banned people are spammers. Because of the way we have VFRWorld set up, it is not that hard to log back in with a new account if you are real and not a bot which he obviously is. Does he cry wolf? Probably so. Do you have to listen, well yes and no. If you are aware of his latest incarnation, just put him on your ignore list and you won't see much out of him. If everyone he bugs does that, AND he doesn't realize you have ignored said account thereby prompting him to create yet another, you won't anyway.
    We don't really want to change VFRworld for the sake of one person bugging people. Maybe he'll get tired of it and just post legit stuff or posts just goofing off like so many others here do. You all have the ability to contact him via PM through the site. Quite frankly, I get tired of trying to ban him. Most people take the hint, he doesn't.
    What's a guy to do?
  10. tinkerinWstuff
    sorry :pout:
  11. Mark 024
    Mark 024 New Member
    Sydney, Aust
    +1 to this. I have been guilty of reading his dribble. This is a great bike, great site and great people and he knows it. Who cares why he does it, he probably wears a Triumph Sprint T shirt and the VFR is his wifes.
    I WILL Ignore!!
  12. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Oh and thanks lgn001 for the write up :thumb:
  13. tinkerinWstuff
    we can start a pledge thread where people pledge to ignore and not feed the troll.
    Can we get a feeding the troll icon or is there one already that I've missed.
    Additionally, if there's a go4 sighting, we can report his latest name so everyone knows to ignore and doesn't get sucked in.
    My beer is empty - irrelevant to the post, I'm just sayin
  14. Mark 024
    Mark 024 New Member
    Sydney, Aust
    He will reveal himself soon enough
