  1. Bryan88
    South Africa
    Durban, South Africa
    Gave her a wash. Because it lives inside and doesn't get ridden in the rain, I'm ashamed to say that washes are far too rare an occurence.
  2. Gator
    Gator Member
    Oil Change and a Honda polish. Then rode the DR 650 all week to work.
  3. NormK
    NormK New Member
    Spent a lot of time looking for the engine number and still haven't found it
  4. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    I read my 83 service manual, and engine number is stamped on the right side of the upper crankcase. Photo shows it under a clamp for a cable, in front of rear exhaust port, below VIN tag on frame. Hope the 86 is the same.
  5. DaHose
    DaHose New Member
    Napa, CA.
    I uncovered her yesterday and took her for a spin. She has been covered for a month or so while it rained and I worked out some kinks in my M6. Hopefully tomorrow will be about putting on a new chain and sprockets and taking a ride around the valley. Yeah it's the Superbowl, but I have no interest in watching either team win.
    Jose
  6. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    I think that's next weekend.
  7. Lint
    Lint Member
    Simi Valley, Ca.
    Installed a fender eliminator that I received from a member here. I forgot his forum name, but thanks Chris!!!
  8. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    New chain & sprockets, repacked the rear hub bearing, rebuilt the clutch slave and master, swapped oil pans, header wrapped the rear header pipes, rotated the linkage triangles, put the newly painted heat shield back on and now working on fixing the ignition switch and adjusting the headlights.
  9. Lint
    Lint Member
    Simi Valley, Ca.
    I forgot to mention that a few days ago, I swapped the front brake pads on the front rotors. The left side was worm more than the right side, due to the whole linked brake thing and I had a brake squeal on light pressure stopping. Also, my brakes were kind of grabbing on light pressure as well. I haven't done anything to a brake caliper in a long time, and I am unable to bleed the brakes on this hose heavy beast, so I took a small stainless steel wire brush and cleaned up the caliper pistons as best I could get to them. There was a black residue on the pistons and I got off as much as I could get to. It's better now than it was and no squeal. I figure by doing this, I should be able to extend the life of my pads, instead of the linked side getting the bulk of the wear.
  10. ridervfr
    ^ I have had to buy a donor caliper in the past to scavenge a piston or two. Its from neglect and not riding.
    You could try the "shoe-shine" method for cleaning up those stuborn stains, simply use a piece of Scotchbrite cut into a strip (I use red or bagged oot green.) and simply go back and forth on sed corrosion offence. You could use 800 to 1000 or so emory paper, worse comes to worse, you have to take the caliper off and use the system to force them oot and then you could do a "proper" overhaul of your brake system. Linked/ABS brakes are a pita imho, I have an air assisted MityVac machine for this stuff which makes quick work of problems of brake/clutch work. Cheers
  11. E.SLC.
    E.SLC. New Member
    Utah
    I was ridding it all day long.... Isn't that what we are supposed to do? :)
  12. PawnBoy
    PawnBoy New Member
    Waterloo, ON
    I fired it up on Saturday, did a battery voltage check and charging system check in preparation for a possible new battery. 13V at terminals right after the float charger was taken off, 14.0-14.1V when the bike was running and 12.8V after the battery sat for a day with no charger.
  13. boy named suzi
    boy named suzi New Member
    I apologized quietly for dragging at her cover whilst shovelling snow. Then I made a mental note to clean out the shed and put her away inside.
  14. duccmann
    E.SLC, did you get hammered this winter?
    Springs right around the corner, no bites on the 1200?
  15. E.SLC.
    E.SLC. New Member
    Utah
    What's up brother?
    No snow this winter it's awesome here in Utah.
    I've been riding in December and January like never before.
    Nothing on the VFR yet. It's one of those.... I'm trying to sell it but deep down I'm hoping not to... We'll see. Maybe I'm asking for too much?
    I hope all is well with you...
  16. duccmann
    Wow thats wounderful. ..keep an eye out for those Utards, some of the worst drivers I ever experienced, and I'm from LA..Be safe bud
  17. Allyance
    Allyance Insider
    Brazil
    Installed Solo Seat Cowl, debating on eliminating handles, that's another $50 in parts. Supposed to come with bike, but I it bought used.
    Ordered custom license plate "RC 79"
  18. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Is that all?:eagerness: you were busy, sounds like a twelve pack day,,,,,,fun!
    John
  19. Veefer Madness
    Veefer Madness New Member
    I installed a Power Commander 3 I bought on this board for $150. Holy Fuck what a great mod! I have no license plate or insurance but I just had to take it around the block for a rip and it did not disappoint. Ever do that when you do something to a bike that you're dying to check out regardless of current legality, so you just go and hope you don't see a cop? It's all part of being a rebel cycle slut from hell livin on the edge.
  20. Terry Smith
    Living the dream! We've all been there.
