  1. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    Yesterday put on a new Michelin PR4 rear tire and took a 75 mile ride to scuff it up. Very noticeable difference! Beautiful 80 degree day!
  2. thx1138
    thx1138 New Member
    Perth
    Took all fairings off VFR750, replaced rear plugs with iridiums, checked rear valve clearances, replaced rear cam cover bolt seals (old ones 4.3mm thick, new ones 5.1mm).
    The other day had removed cluster and replaced most bulbs and stripped it to remove dust, dead insects and spider webs. Looks new now.
    Front head tomorrow for same treatment. Then coolant flush.
  3. UJMan
    UJMan New Member
    Charlotte, NC
    Let me know what you think of it once you get it scrubbed in. I am due pretty soon, and have been trying to compare PR3, PR4, and PR4 GT
  4. Allyance
    Allyance Insider
    Brazil
    I have a new front tire as well, will get around to that in a week. I am not a high performance rider, but I did notice one corner I usually take @70, I was pushing 78 with a lot more confidence.
  5. duccmann
    Allyance, so this is on your 14 right? How many miles on the stock tires?
    P4 are great
  6. rvmiller
    rvmiller New Member
    Tampa, FL
    Went on a group ride which ended at a MotoGP party...
    Ride Red!
  7. Allyance
    Allyance Insider
    Brazil
    I got 4979 on rear before changing, could have gone a little further, but I was anxious to try PR4's. Will wait a little long for the front. Rear tire required loosening muffle and swinging out of the way. Don't have a safe way to support bike to lift the from off the ground, no solid point underneath to jack it. Front pipes come down and are in the way.
  8. DriverDave
    DriverDave New Member
    Denver, CO
    I only got 3020 miles out of the oem Dunlop rear on my 2014. Now have about 3000 on PR4's, and couldn't be happier. Looks like I should get 5k to 6k out of the rear, even more from the front.
  9. RobVG
    RobVG Member
    White Rock BC
    Brakes
    Was tempted by the $15 full set of pads on Amazon but went with EBC OEM type- $90. I ran into a few issues but I'll save them for a blog post. Took it out for a few laps around the lake.
    I think I know why dealers won't work on older bikes. Maintenance and repair procedure times probably don't inclued added time for corrosion.
  10. Lint
    Lint Member
    Simi Valley, Ca.
    This was from a few days ago, but I put a full set of EBC HH pads on my bike. Wow, what a difference! My front pads were pretty bad, with the right inside pad being very close to metal!
  11. Slothrop
    Slothrop New Member
    northern lower Michigan
    Ordered new springs for the starter clutch on my '96, along with the right side crankcase cover gasket. The starter has been acting wonky for a while now. When I finally opened it up this weekend I was expecting to see the starter clutch cracked into pieces as I've seen examples of on here; but it was in good shape. The only thing I noticed was one spring quite a bit weaker than the other two. Hoping that replacing them will fix the intermittent issue.
  12. Aimbot9000
    Aimbot9000 New Member
    Mount Holly,nc
    New chain& sprocket kit and installed a pro-oiler
  13. Gator
    Gator Member
    New tires time. So I burned off the old rear.
    [video]https://youtu.be/oz6ImYllUWA[/video]
  14. Gator
    Gator Member
    Didn't do a traditional power braker. With linked brakes I didn't want to wear the rear brakes down. Hence the wall. ^
  15. drlovjr
    drlovjr New Member
    changed my pr3 rear tire for a pr4.can't wait to test it, still cold in mtl Canada
    drlovjr
    winter-impreza outback sport 2004
    family-mazda protégé wagon sport 2011
    liberty-Honda vfr 2008
  16. drewl
    drewl Insider
    Virginia Beach, Va
    Just changed the front brakes.
    Original set lasted 50,000 miles...as far as I can remember. I could be wrong.
  17. duccmann
    Nice Gator
  18. Alaskan
    Alaskan Member
    Alaska
    Wow. 50,000 miles on a set of front pads?
    Mine lasted about 22,000 miles.
  19. OOTV
    OOTV Member
    The front SMC has to be triggered for it to activate the rear caliper. As long as the front wheel is not spinning, there will be no centrifugal force on the rotor to trigger the SMC. But your method works too!
  20. superpsu
    superpsu New Member
    Cortland, NY
    Installed 6000k hi and low HIDs today and changed chain (put on Tsubaki) and sprockets (dropped a tooth on front) a couple weeks ago. Rode it a few miles today to check out the lights and see how new chain felt.
