  1. Wheatchex
    Wheatchex New Member
    Canton, OH
    Took both wheels off today in prep for new tires coming in this week. :)
    Brian
  2. 34468 Randy
    smoking combined with this is very bad!
  3. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Worked on the '83 today, buffed and polished my stator cover, cleaned off old and grease off engine and frame with simple green, removed fox shock to remove rear exhaust pipes for wire brushing and hi-temp painting.
  4. Lint
    Lint Member
    Simi Valley, Ca.
    Tightened up the shifter lever bolt. it actually came loose. Not loose enough to fall off, but enough to give a fair bit of play. Maybe the culprit behind missed shifts/coming out of gear. I may have thought it was fully engaged, but it wasn't.
    Check yours. 1/4 ratchet, 10mm socket.
  5. Lint
    Lint Member
    Simi Valley, Ca.
    Actually, a cigarette burns too cool to be an ignition source. It won't even light gasoline which is much more volatile....
  6. Gator
    Gator Member
    I have used lighter fluid for a very long time with great results. By the way you can put a cigarette out by dropping it into gas, won't blow up or ignite like in the movies. If your worried about combustible sources worry more when your using carb or brake cleaner.
  7. VFR714
    VFR714 New Member
    Nothing much. Just undress her want to explore her naked.
  8. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    Paid up my NY reg.
  9. jorgescar69
    Bout to start the long drive to Maryland and ride me bike back to NY.
  10. ridervfr
    Nice, safe riding :thumbsup: Got a new used shock for my 93...
  11. HawkhoundVA
    HawkhoundVA Member
    Virginia Beach, Virginia, United States
    I can ride legally Now... Finally got my tags and registration, took like forever... DMV is so awesome:mad-new: in VA.
  12. sunofwolf
    sunofwolf New Member
    added 1.12gals of 87 to tank, I ran the bike almost to empty. One dash of fuel stabilizer .
    that is all-oh I turned it around in garage to face out-put cover back on-the beast
    took a break today had a head ace :alien:
  13. jorgescar69
    Got to Baltimore finally. Was away from her for just a few weeks n the spiders moved in.
    so off to the coin car wash.
  14. Lint
    Lint Member
    Simi Valley, Ca.
    Oil change and lived the hell out off the chain.
  15. duccmann
    Is that what they call lubricating the chain these days ha ? Hope ya got the kink out brotha man
  16. Knife
    Knife Member
    Downingtown, PA 19335
    Getting ready to install DMr forks and a 929 shock, all built by Jamie Daugherty.
  17. Motographer
    Motographer New Member
    Nashville, TN
    Installed Delkevic 8" cans on my '07. Didn't have anywhere near as much trouble getting the factory luggage racks on and off as I'd been led to believe, and the rear bodywork comes off very easily to boot. Took some fiddling to get the cans fitting right, you have to replace the whole exhaust system from the cat on back, and there are four separate pieces that make alignment a bit of a PITA. One of the cans is turned slightly more than the other, but I hardly notice it. There's 1/2-3/4" clearance between the racks and the cans, and a little more empty space under the bodywork, but it looks fine. The upshot is that the bike sounds FANTASTIC now, just like an RC213V when it's revved up. Tried to take a video on my phone, but the mic clipped so badly that it sounds like someone gargling water and nothing like normal.
    Also ended up making a poor man's fender eliminator when I accidentally broke one of the stock fender mounting tabs trying to loosen the screws; one of the ones with the square nut assemblies on it tore right off, so I ended up just tossing the whole fender and bolting the license plate and light assembly to the fender mounting bracket. It actually mounted up perfectly, and didn't cause any problems with the luggage racks either.
  18. duccmann
    Pictures Mr. Moto
  19. Motographer
    Nashville, TN
    IMG_20150517_141309~2.jpg IMG_20150517_141319.jpg IMG_20150517_141331.jpg IMG_20150517_141347.jpg IMG_20150517_141403.jpg
    As requested.
  20. duccmann
    Looks awesome, hows the sound?
