  1. THRASHED
    THRASHED New Member
    San Dimas, CA
    Better man than me. Mine will be going to Race Tech for their seals/bushings. By the time I buy tools etc, it's only $90 more to have an expert take care of it.
  2. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    I spent $1 at homedepo on a pvc conector to use as a seal driver
  3. sunofwolf
    sunofwolf New Member
    put 1/2 gal of 89 in tank- just enough to go on a ride:pisser:
  4. THRASHED
    THRASHED New Member
    San Dimas, CA
    The thought occurred to me. Straight slip fitting, what size?
  5. jorgescar69
    Hers the part number
    you're gonna have to sand down or file or dremal the little lip inside for it to work.
  6. THRASHED
    THRASHED New Member
    San Dimas, CA
    And then just press them into place? Sounds simple enough. I've got a bunch of forsner bits, I'm sure one of them will make quick work of getting rid of the insides stops. One more thing to tackle.
  7. thx1138
    thx1138 New Member
    Perth
    Spent a couple of hours watching "Hot Fuzz" and working on the replacement wiring harness for the vf1000r mark 2. Much cleaning, re wrapping, and cleaning of brass connectors.
    The one on the bike is so butchered I wouldn't know where to start.
  8. duccmann
    Just got done cleaning my K&N filter.....waiting till the first week of July to change my oil for the Laguna ride.
    Tick tock
  9. Lint
    Lint Member
    Simi Valley, Ca.
    I just sync'd my starter valves. Now I just need to ride and see if it makes a difference!
  10. JTB488
    JTB488 New Member
    Just had some new Michelin Pilot Power3's spooned on. Since this weekend calls for rain doing the spark plugs, new front rotors and pads.
  11. OOTV
    OOTV Member
    Were they far out of sync before you did this?
  12. jorgescar69
    went for a 70 mile ride. added 3.2 gal of fuel @140 miles on the trip.
    stopped for smokes n a dude on a Hog pointed out i was leaking from the radiator.
    J B Weld was used to fix a few holes on the radiator.
  13. Scotto
    Scotto New Member
    Pulled off the OEM can and slipped on an aluminum Two Bros M2.
  14. Darth Vader
    Darth Vader New Member
    melton mowbray
    Sync,d my starter valves then went for a ride.
    Starts so much better now and hit 100 for the first time.
    My God these things go like the wind.
    Came home with the biggest smile.
  15. JTB488
    JTB488 New Member
    Got the rotors and pads done. Flushed the brake fluid with new Motul 600. New NGK plugs. Installed the PCIII.
  16. HondaCrazy
    HondaCrazy New Member
    First oil change, wow was it dirty, s milky brown/green. Cleaned and lubed chain while I was at it.
  17. duccmann
    125 mph..easy peasy
  18. Outboard John
    Outboard John New Member
    Escondido, Ca.
    That sure is a Purdy exhaust can:loyal: congrats.
    John
  19. CaribooBC
    CaribooBC New Member
    100 Mile House, BC
    That doesn't sound right, oil should not be milky.
  20. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    Sorry to say, milky oil means water leak in oil supply. Head gasket? run for a little while, and check old again, if still milky, need to check for leaks.
