  1. bk94si
    bk94si Member
    I was out for a ride and stopped for some frozen yogurt. Came back to the bike and the battery was dead. As in, turn the key, everything lights up and then slowly fades away (or immediately if I actually tried to start it). Fortunately, Walmart just across the parking lot. Walked over bought a battery, came back and installed. I do need to check the voltages now that I'm home but I need to cool off first. Lesson learned. I've been suspicious of the battery already because of its age and I should have replaced it before it left me stranded. I bought the bike used 9 months ago and I had noticed that battery was old already.
  2. Blackslide
    Blackslide New Member
    Finland
    Got new tires.. but had to roll them into storage.. :([​IMG]
    Riding on the storm
    CDA441 likes this.
  3. Microwavable
    Microwavable New Member
    New Zealand
    Levin, New Zealand
    What have I done with my VFR800 today? I gave it to my wife for passing her Full licence exam lol
    Thumbs, OOTV, Zapp and 1 other person like this.
  4. Thumbs
    Thumbs Member
    Bath(ish)
    A7A9C583-BFFE-484C-952B-DCF6EDDBB8FA.jpeg Fitted DSG frame protectors
    VFR1200, 4corsa and fink like this.
  5. highway star
    highway star New Member
    North Mississippi
    Changed coolant. Engine oil & filter. Detailed & waxed.
    Adjusted a bit of the slack out of the throttle grip.
    Took off the airbox rubber snorkel, should get more air?
    Sure seems it should breath better.
    Oh & when I took the airbox lid off to check the filter, the flapper
    vacuum module was just hanging, it had come unclocked & fallen down!
    Bent the tabs a bit and it screwed on tighter.
  6. VFR1200
    VFR1200 New Member
    Calgary, Canada
    The small box arrived. Now to start the service.
    Service the clutch slave. Replace spring and rubber cup. Bleed clutch.
    Front fork seals and oil. Just waiting for Ohlins springs to arrive.
    Headstock bearings.
    Oil and filter change.
    Replace radiator cap. (This one seemed strange to me. But the Honda tech said the spring looses its tension overtime, this has an affect on cooling ability over time, by more than 10%. The bike used to heat up fast. I had a coolant flush recently and at times the bike gets hot really quickly 215 F. It cools down etc, but it also then heats up just as quick. No where near as bad before the flush. So I will try the cap.
    My bike is a 2007 VFR800 Anniversary. It sat for 11 years and wasn't used by the previous owner. It only had 1900km when I bought it last year. This is why I am replacing all the consumable parts.
  7. bk94si
    bk94si Member
    Replacing my cush rubbers today. Wow, I don't think this cush drive has ever been off the bike before. Totally corroded/welded together. I took to hitting with a hammer onto a piece of 2x4 but it didn't finally come loose until I took to hitting the axle directly with a sledge hammer (which I didn't want to do but I did manage it without damaging axle. Time to take a break before putting it all back together. And I thought this would be a quick and easy job...
    simba_rr likes this.
  8. duccmann
    Well tomorrow have to swap out that little plastic speed censor nut on my 02.
    Anything I should know for this 5 minute fix?
  9. Doug7200
    Doug7200 New Member
    El Segundo or Gardnerville!!!
    OK, Had a full maintenance and upgrade day.
    New Pirelli Diablo Rosso front
    Finally installed Power Commander and O2 ends. Found a new place to mount the PC also - Sideways next to rear brake fluid reservoir. Fits well, easy access to adjust, and it frees up under seat storage too.
    Installed headers and swapped on my Scorpion exhaust cans for the Delkevic's - which were way too loud for me. Back to a nice low rumble!
    Pair delete
    Installed Throttle Master bar ends with throttle lock
    Installed a 3mm shim under rear shock
    Lube here and there, a little wiring clean up/organization
    Gave her a good wipe down and a little polish too.
    Bummer I'm out of town for a couple of weeks...But she's ready to go when I get back!
    Bubba Utah, 4corsa and OOTV like this.
  10. Diving Pete
    I also have the Delkevics (& like them !) - do you also run the baffles - I don't & the bike sounds just amazing..
    4corsa likes this.
  11. osoamazin
    osoamazin New Member
    Sacramento, CA
    Changed the battery for a Yuasa 14. Wow! What a difference. Now, to check the voltages and look toward replacing the R/R with a mosfet one, just to be on the safe side. Planning to put some miles on this baby and don’t want to get left stranded!
    VFR1200 likes this.
  12. bk94si
    bk94si Member
    New cush rubbers made a huge difference! Shifting is so much smoother now. The old ones didn't look too bad but they must have been hardened more they appeared to be.
  13. CDA441
    CDA441 New Member
    Belgium
    Gots me 8 spoker, stripped it, sanded it, and painted it. Then went to the tire shop and they made a gash in it. F*cking idiots.
    Repainted/touched up and clearcoated it, now it's still drying but I couldn't just let it sit there not being on my bike :D
    The most expensive thing when refurbishing this wheel was the can of paint stripper, and it wasn't even good paint stripper...
    Doug7200 and Bubba Utah like this.
  14. Bubba Utah
    Bubba Utah Member
    Utah
    I have the Delkevic shorty with the baffles in. Too loud for me without and for the local law enforcement. Yet Harleys can get away with straight pipes. They just hate fairings. ;-)
  15. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    Rear tire time.
  16. bk94si
    bk94si Member
    Slightly.... ;)
    jorgescar69 and Bubba Utah like this.
  17. Diving Pete
    Try leaning the bike more - it will give you more tyre to wear out other than the centre 2 inches..
    jorgescar69 likes this.
  18. Doug7200
    Doug7200 New Member
  19. Doug7200
    Doug7200 New Member
  20. Norse
    Norse New Member
    Denmark
    Fiberglassed the holes where the front indicators used to be. Time to get rid of those hideous orange things.
    4corsa likes this.
