  1. ictghost
    ictghost New Member
    Kansas, the Land of OZ
    Today, I rode the VFR in a hard rain. Something I usually HATE, but with the heat the past few days I didn't get mad at all when I was caught several mile from home. Plus, she's really clean now!
  2. smooth1
    smooth1 New Member
    Hey you guys, i haven't had the pleasure of dumping a rectifier yet, but, in time I'm sure....anyway, may I offer this comment...The other day I replaced the "original" battery on my '06. That hot plastic smell is gone! Maybe some of the issue is just OLD batteries in our bikes and the recharging system as a whole is over taxed. Around 300 miles later... So far, so good. I'm no expert, but maybe battery replacement is a good idea if ya get that smell...Like I said, worked for me.
  3. JTC
    JTC New Member
    Watts, CA
  4. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Hot plastic smell? Check you 3 Pin connector int the leads for the stator to the rectifier. Look for any discoloration due to heat. If not melted, then take apart and thoroughly clean and rough up contacts. I use am emery board trimmed to fit inside female connectors (peel off rough sand paper, only use one side).
  5. NormK
    NormK New Member
    Could be part of the cause, but we know the connector is the biggest cause of charging problems, so why not fix it before you cook everything, prevention is the best form of maintenance, not fixing it after the event
  6. smooth1
    smooth1 New Member
    ...And my next project is...Thank you NormK and Allyance!! ...just popped the right fairing, yep that connector is brownish. getting dinner then I'm going to hard soldier the wires and shrink cover 'em. Thanks again guys!
  7. NormK
    NormK New Member
    Connector was the burning smell not the battery, glad you checked
  8. duccmann
    Went over intire bike, oiled chain like always and changed the oil.....
    Ready to Rock
  9. superpsu
    superpsu New Member
    Cortland, NY
    Changed the oil on my 2002 sliver vfr vtec with royal purple max cycle 10w-40, added coolant to the overflow reservoir, and gave it a wash afterwards.
  10. GigemVFR
    GigemVFR New Member
    TEXAS
    Thorough washing first. Then hand polished and good coat of wax. Light polishing compound on wheels to bring back shine and good coat of bike spirits on other black plastic parts. Have not see it look this shiny for long, long time.
    Up next, clutch and brake fluid flush and new rear brake pads.
  11. whiteknuckles
    whiteknuckles New Member
    Beaverton, OR
    PAIR removed, rear brake switch adjusted after I figured out it wasn't bad bulbs or wiring and the brake lights were always on (new VFR owner).
    2 weeks ago - New coolant, thermostat and associated cooling hoses, and replaced all throttle body vacuum lines while I was there for piece of mind, plus EVAP Canister now gone.
  12. thx1138
    thx1138 New Member
    Perth
    New steering stem bearings fitted to the 84 VF1000RE.
    Headlight and front cowl fitted to the 94 VFR.
  13. jackhammer63
    jackhammer63 New Member
    Avondale,AZ
    Installed a universal Vista cruise control.
    Getting ready for a long road trip.
  14. icycle2much
    icycle2much New Member
    North Carolina
    Would you please post a picture of this universal vista cruise? Thanks
  15. mhaas
    mhaas New Member
    Upstate SC
    I test rode the 2k VFR after a few rounds of quality garage time. installed GTR bars, hung OEM muffler on the TB header, installed LED instrument lamps and took the windscreen to the band saw. The throttle cables are stiff in new routing and will need to be longer. After 4th July road trip will track down new cables.
  16. jackhammer63
    Avondale,AZ
    $40 at cycle gear. Took 15 min to install.
  17. jackhammer63
    Avondale,AZ
    Got a new Sedici expandable tank bag.
  18. crashburn
    crashburn New Member
    Montréal, Québec
    Installed LED headlights, and clear LED equipped front turn-signals and rear tail light.
  19. sunofwolf
    sunofwolf New Member
    How about this -I ride the Mad Max Black Beast today- and believe me its a bike to get noticed on-nobody has a vfr like mine- I did hit a Pedo today 3" that shock me up-scotts damper really does help-my fairing took a big shack. Boo Boo BB.:vtr2: I could pop a wheelie.
  20. mhaas
    mhaas New Member
    Upstate SC
