  1. raYzerman
    raYzerman Member
    Millgrove, ON
    They are testing recovered people for anti-bodies in the hopes they can get some useful information.
    wiremanjon and duccmann like this.
  2. HotPursuit
    HotPursuit New Member
    SoCal High Desert
    I fabricated a harness to physically attach my magnetic tank bag. I stopped trusting the magnets when I got caught in some high crosswinds on a day ride, and it blew the bag of my tank and (luckily) into my arm.
    I made the harness from 1" nylon web strap and buckles. I had to stitch a couple straps and buckles to the bag, and that was probably the most time consuming part, since I stitched it by hand. I used heavy duty nylon thread.
    Not the prettiest, or maybe even lightest, but it's secure, and I can still easily remove the bag to get to the gas tank. I can still remove and replace the harness as well without having to break out any tools.[​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my SM-G965U using Tapatalk
  3. Norse
    Norse New Member
    Denmark
    Took the old war horse for a little ride. About 250 miles. Almost all Motorway at 88-90 mph.
    Pretty surprised by the mileage it gets with the new pipes and gearing. Race headers and pretty much open can + 16/45 gearing. The second to last line on the fuel gauge dropped at just over 182 miles. That should mean around 205-207 miles to a tank.
    That is quite a bit less than before, but quite a bit more than I expected.
  4. Samuel
    Samuel Member
    Los Angeles County
    Some neoprene or other soft padding material between the straps and your tank may help prevent scratches/wear...
  5. HotPursuit
    SoCal High Desert
    I'll consider it. The harness itself shouldn't move or vibrate any to cause wear. The bag is also still magnetic, and holds itself in place for the most part. The harness is just a failsafe in case the magnets don't hold tight enough against crosswinds.
  6. raYzerman
    raYzerman Member
    Millgrove, ON
    I stared at mine, waiting for a fuel tank gasket.
  7. Microwavable
    Microwavable New Member
    New Zealand
    Levin, New Zealand
    Why not get one of those tank bags with the locking ring, I have one and love it, no scratches
    Sent from my SM-G935U using Tapatalk
  8. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    Pumped up front tire, leaky cheap Chinese right angle valve, then went for a brisk ride in 80 degree weather. Will replace valve when new tire comes in, going to stick to old fashion self sealing rubber valve stems. Went from 32 to 4 lbs in a week!
  9. wiremanjon
    wiremanjon New Member
    Morris County, New Jersey
    I love my right angle valves. Maybe try a different and higher quality type? They make my life sooo much easier.
    34468 Randy likes this.
  10. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I bought the ones from KurvyGirl, and am very happy with them. No leak down.
    On edit, corrected misspelling.
    34468 Randy and 4corsa like this.
  11. 4corsa
    4corsa New Member
    I also installed Curvy Girl. All good - no leaks after 1 year. So much easier to check pressure on the front tire!
  12. 34468 Randy
    I am on my second set and never had a leakage with either. The first set were chromed with a curved corner but they pitted and looked ugly so on the next tire change, I went to billet cut aluminum anodized red and have had them on for several years now with no issues. The only thing I don't like about them is you have to find another way to introduce dynabeads into your tires. If you use weights, then this is not an issue of course.
  13. HotPursuit
    SoCal High Desert
    I use Ride-on tire sealant, which also can be used to balance your tires the same way the beads do. Just remove the valve core, squeeze in the amount you need for the tire, then put the valve for back in and air up the tire. I didn't have any issues every with a 90° valve stem. I've been using this stuff for both my bikes, and it's worked great
    The tire Slime stuff won't balance your tires, and doesn't congeal/stick to the tire wall as well as Ride-on.
  14. NorcalBoy
    Always used Ariete stems.
  15. Allyance
    Allyance Insider
    Brazil
    Yes they are convenient, CycleGear replaced with another one when I got the last tire. Pain in the ass to keep taking the wheel off and to pump up. Front wheel on the 8th gen have little clearance. Where did get yours? What brand? My rear tire doesn't leak, and I still have one on that rim.
  16. wiremanjon
    Honestly I don’t remember, my bud worked in a Honda dealership and I gave him my rims at tire changing time and told him to put the right angle valves on for me. There are plenty of responses above⬆️ That people recommend specific brands.
  17. NorcalBoy
    I believe the right angle valves that Julie from KurvyGirl sells are the Ariete/Bridgeport version 2's. Julie is super responsive on orders and will typically get them out the same day. I have bought a lot of bits and pieces from Julie and I totally recommend her and her company.
    mhzpower likes this.
  18. OldSchoolInterceptor
    OldSchoolInterceptor New Member
    Spokane, WA
    Must have been a tough job getting the hub off a 5 bolt 8th gen to fit a 6th gen. It’s beyond my skill set but it looks Rad!!
  19. Dennis The Menace
    Dennis The Menace New Member
    Cambridge Ontario
    its been neglected for a long time. so over two days
    Air Filter
    plugs
    oil and filter
    coolant
    brake pads
    brake fluid
    speed bleeders
    clutch fluid
    I think thats it.
    oh and wash and wax
    then it friggin snowed again today
  20. Billy Jack
    Billy Jack New Member
    Vfr has been quiet for a few weeks, just chilling on a tender right now. Been thinking about buying a Hurricane handlebar kit from Web bike Japan. Not the huge tall cop bike bars but the lower ones that make cruising around the city much more comfortable.
    I’ve had the bike for damn near 11 years and the only mod is lowered pegs using the BLS lowering blocks. Maybe one day I’ll make the change.
