  1. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    So after last week's deal sucking gas like an F250 truck, i changed the oil n filter.
  2. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    I took my VFR out riding. The shop had a group ride and I always go to help out. The VFR and I did about 160 miles. I had a blast but it started to get really hot around 11am. I have decided not to pay too much attention to the fluctuating numbers on the temperature readout. The only time I got concerned was when it briefly climbed to 228 degrees.
  3. icycle2much
    icycle2much New Member
    North Carolina
    Changed oil to Amsoil 10w-40, installed new oil filter, installed K&N air filter and put back on the stock windscreen
    Then rode 200miles to the NC mtns
  4. jorgescar69
    Test fitted the projector setup. I would have done it all if would have had the ignition boxes with me.
    i dont want to Bucher up the Airteck just yet. Not till im happy with the whole package.
  5. THRASHED
    THRASHED New Member
    San Dimas, CA
    Rebuilt the clutch hydraulics...again. When I brought the bike back to life the only thing I replaced was the rubber stopper in the slave cylinder and the clutch was functional but would bleed off pressure (change in contact point) while sitting for a long time at a light. About two weeks ago, I ordered the master cylinder rebuild kit and installed it. Nothing but problems since then. The clutch engagement point was inconsistent and seemed like it was hanging up, then engaging (hate stalling a bike...anywhere). I ordered a new slave spring and shaft seal washer and installed it last night. I noticed that the slave plunger (metal) still had a little old buildup. A few minutes with a scotch brite with brake fluid as lube and it cleaned right up. I then greased (just a film) the inside of the slave cylinder and the clutch rod cup. Next, back to the master. I pulled it apart again and noticed a rough spot just on the other side of the vent holes. Again with the scotch brite wrapped in a screw driver to rub it out. All back together now and working perfectly. :tranquillity:
  6. jorgescar69
    So i was back at it again.
    Replaced the wire harness. Then was greeted with a dead stator! It was grounding. Since i have a spare engine, i just did a swap. Charging at 14.8 volts now. Will have it all back together in the morning.
  7. ridervfr
    Been there, did the wiring harness on my 91 a while ago. I installed a new r/r the other day and just started it to check charging. 14.25 at 3000 rpm, up to 5000 rpm stays about the same. Old r/r was at 13.80 or so; its amazing how well that motor sounds I gota say even with all those miles. Both r/r were are Mosfit btw.
    Good job with the wiring! Thanks for sharing ; )
  8. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    After 20 years, the RR finally died. I replaced it and reset the timer for 2035.
    mhzpower likes this.
  9. TonyD
    TonyD New Member
    Missouri
    Since I just got the bike this week, I changed the oil, checked the air filter, cleaned and lubed the chain, and took a short ride!
  10. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Drove to the border to pick up a bunch of parcels which included new riding boots, backup thermostat, voltage readout, GoPro sticky mounts, tank protector, and an extra helmet visor.
    I washed the biked today and also started test loading it with all my gear for the trip.
    Tomorrow, I'll mount and hook up the voltage readout, and finish loading the bike up so I can set the suspension.
    Later this week, I'll be replacing the front tire and all the brake pads ... then I'll be set for the trip. :)
  11. jackhammer63
    jackhammer63 New Member
    Avondale,AZ
    Been a busy weekend.
    Replaced the chain and sprockets.
    Flushed the coolant.
    Changed the oil.
    Discovered that there were missing bolts on the fairing so I replaced the four that are holding the piece in front of the exhaust. Relocated the others to any other missing places.
    Installed the passenger grab bars purchased from eBay for $108.00 USD.
    Took her for a spin around the neighborhood. She is just about ready for the Sturgis road trip.
  12. Alaskan
    Alaskan Member
    Alaska
    New tires.
  13. duccmann
    Bitchelins?
  14. jorgescar69
    Well i ordered a new tire.
  15. adeyren
    adeyren New Member
    Worcester UK
    Picked up a complete R1 front end for my winter project.
  16. jerritt
    jerritt New Member
    Toronto
    shimmed the rear shock 4mm the front already is lowered 10mm. I'll see if it needs more or not after a nice spirited ride. anyone have some input on the matter
  17. Alaskan
    Alaskan Member
    Alaska
    Natch!
  18. Alaskan
    Alaskan Member
    Alaska
    Why did you buy a new one? That one just wore in.
  19. jorgescar69
    and i got it today!
    That tire was so much fun. Can't wait to do it again.
  20. jorgescar69
    And its installed!
