  1. duccmann
    Wow, very cool
  2. Grumpy old man
    Grumpy old man New Member
    New Zealand
    Cambridge, New Zealand
    So its run in finally
  3. Allyance
    Allyance Insider
    East Bay, California
    Rode my '83 VF750 to work, first time in 26 years!
    Before she was finished.
  4. ridervfr
    ^now its all down hill at work, your gona be known as the "motorcycle" person. Need to brake them in.
    Congrads on that 100,000 mark!!! I have a long drone to work now, same amount of miles as before, seems more boring as its all slab work, I will start taking a bike in the near future just like all my jobs.
    Cheers.
  5. Knight
    Knight New Member
    USA
    One million miles! AWESOME! That's because it's a Honda.
  6. THRASHED
    THRASHED New Member
    San Dimas, CA
    Whoa!!! Slow your roll a bit there buddy...LOL. Thats 100k. 1 Million? I think Paradox would change his name to IronAss.
  7. Lint
    Lint Member
    Simi Valley, Ca.
    I cleaned the chain with kerosene and a toothbrush. It's clean now!!! Even the hard to get parts are. Anything I missed was flushed away with the chain lube. It looks pretty good!
  8. thecat
    thecat New Member
    Finally got there with some electrical bits. Replaced the 30 amp fuse to battery terminal with heavy duty narva auto fuse holder. Found that the skinny wire leading from the stock honda fuse holder to the terminal was seriously corroded. Apart from the exterior contained by the sleeve, majority of inner strands were black from oxidation. Horrible to think what an electrical bottleneck that was.
    Since i have a new stator and rick's Motorsport r/r, decided to do away with plugs. Was recommended heat shrink solder splices and amazing for me at least to watch them installed using a hot blower gun. I am told the joint will be it waterproof and airtight. Fit and forget. Solid connections once the joint cooled down no question.
    Battery tested. 13.2 volts. Started engine and from 2000 plus rpm rock solid at 14.5 volts. Good to have got that done.
  9. Badbilly
    Knight says he is an engineer. I think he dropped his slide rule someplace. ;)
    This one is supposedly true. A guy bought a BMW and followed the maintenance schedule to the letter. Rode the bike a million miles. BMW it is said, bought the bike back from him, put the bike in their museum and also gave him a brand new bike..
    mhzpower likes this.
  10. catawalks
    catawalks New Member
    Replaced my front forks, cleaned the crap out of my front brake rotors, and finally installed my throttlemeister cruise control again after it fell if while riding a couple weeks ago.
  11. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    Road the hell out of it...
  12. Lint
    Lint Member
    Simi Valley, Ca.
    *Rode*
    I hope you had fun!
  13. jerritt
    jerritt New Member
    Toronto
    Installed my pcIII
  14. jorgescar69
    Ok... so I decided to replace the rotor.
    This is how far I have gotten. Im banging it with a malet.
    Shouldn't it just slide out!
  15. Terry Smith
    At this point the answer is yes!
    I was going to do the same so I could clean/lube the eccentric and bearings, but I couldn't shift the axle. I decided to give up as it was preventative maintenance, not something essential.
    Apparently just the grease or rust on the axle is all that is stopping you slipping it out. Give it some welly, man!
  16. jorgescar69
    I beat it out till the 2x4 splintered.
    Done baby.
  17. ridervfr
    :thumbsup: I had total faith...:mech:
  18. catawalks
    I found a leak in my front wheel on a bend in the rim. That bend had been there for as long as I've owned the bike and never leaked until today. Got to work with a front flat and had to take it all apart. Luckily the school I work for has an auto shop. Used one of these to break the bead, toss some bead sealant in there. Now I just need to put it back together and hope it lasts the 56 mile ride home.
  19. Grumpy old man
    New Zealand
    What sort of bearings are in there ,I was lead to believe it was a double type of ball bearing on one side and a tapered bearing on the other side
    If this is the case and the axle is seized against the bearing housings wouldn't bashing the Crap out of it possibly damage the Bearings / races
    Or is the interference solely from the splines rusting ?
    Just asking as I received my 46mm socket today so I can re-grease or swap out the bearings in my 04 since I have no idea if it has ever been touched
  20. Allyance
    Allyance Insider
    Rebuilt starter switch on the 1st gen. Cleaned and burnished contacts, then used J-B weld to fix broken pivot pin. Should last another 30 years!
