  1. Gator
    Gator Member
    Well you have a wife that lets you ride and own several bikes, that is a total win. I have had friends that lost their riding card with marriage..... and obviously their nuts too. lol
  2. Knight
    Knight New Member
    USA
    I started riding after getting married. That's how cool my wife is. Even after seeing the costs of a sport bike she seems open to a Ducati as a second bike. Can she be any cooler? I don't think so.
  3. Terry Smith
    I use this one (not shown actual size):
  4. Gator
    Gator Member
    I don't see the medulla oblongata......... lol
  5. Terry Smith
    Shoot, so that's what fell on the floor when I pulled it out! Thanks Gator, I'll go looking...
  6. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    Two weeks ago I found my battery had drained from sitting. So today I charged it and rode it hard... to the gas station. I have not had a good weather day to ride since befor I changed front tires. Continental made a bade one. It happens. It is about 38 out today on the shore of Lake Erie and feels like 32 with the wind chill.
    I love Western New York.
    With not much ride weather... the snowboard gets the job done!
    this was Friday. 13" of fresh powder.
  7. squirrelman
    Dija mention which track that is ??
    Watching those videos actually gets my heart beating faster !!
  8. OOTV
    OOTV Member
    Back at post #1100, It's Chuckwalla Raceway in the Palm Desert. If you really want to see how fast one can go on this track, check this one out. This should really get your heart beating much faster!
    [video=youtube;ObX4xiCc7qo]http://www.youtube.com/watch?v=ObX4xiCc7qo[/video]
  9. redwing750
    redwing750 New Member
    Buffalo NY
    Rode out to meet Mr Squirrelman, great dude and knows his stuff!
    While we were standing outside chatting we hear a rrrrrrrRRRRRRRRIIIIIIP- THUD -Scraaaape
    Looked over just in time to see a guy mid-sail and an older yellow ZX7R sliding on the pavement. Oh SHIT
    Mind you, on the 2nd of February in Buffalo, bizarre enough by itself haha.
    So the kid gets up and thankfully was alright, he either gave bad/overoptimistic input because it looked like the bike did a sideways wheelie/ rearspin into the car.
    Dead cold tires surely did not help.. and he was riding solo on a permit... ooops!
    One way or another the bike got away or he bailed simultaneously, but it was obvious to him and all witnesses the ZX did not want him on it.
    Bike ended up smacking a Honda Civic waiting at the light, and skating some distance down the street.
    I was going to take a pic but figured the kid was embarrassed enough...
    Nice meeting ya Squirrel :)
  10. Terry Smith
    I fitted a used disc on my 99 and took it for a test ride last night. I was getting some braking vibes which I had attributed to a slightly bent (but inside allowable tolerance) right disc. After fitting the new disc it was worse!
    I re-checked both discs using a dial indicator gauge and there's almost no runout (about 0.05mm max) on either, and I rechecked all fasteners, emery-papered the new disc and also the pads, but no improvement. So I started checking bearings and bushings and found the front wheel bearings were pretty loose. I'm not sure why this would cause severe juddering under brakes but I guess I'll find out once the new bearings go in.
  11. crustyrider
    crustyrider New Member
    North Country, New York
    I went out and put the tarp back on it .. then kicked it for good measure...
  12. 34468 Randy
    Did you consider doing that bobbin cleaning exercise?
  13. Terry Smith
    Yes I did that before I installed the new disc.
  14. Gator
    Gator Member
    Thanks for that, those guys were hauling the mail! I think they are 600's running around 15-16k rpms.
  15. Outboard John
    Outboard John New Member
    Escondido, Ca.
  16. OOTV
    OOTV Member
    Yeah, that's the place. I appears to also be called Chuckwalla Valley. Regardless, the guys in that video make it look like i was going in reverse!
  17. Terry Smith
    Continued work on getting rid of the brake shudder. Replaced the front wheel bearings and went for a test ride but no improvement. Definitely presents as variable disc friction, so not calliper or pad related as the brake force variation matches the wheel speed. So I got out the 220 grit sandpaper and went to work on the disc, then followed up with brake cleaner. Accompanying wine meant no more test rides tonight!
  18. ragincanadian
    ragincanadian New Member
    Ottawa
    Installed right crankcase cover, alternator cover, pinion cover.
    Cleaned the chain *should have taken before and after pics. I thought I would need a new one for sure but it cleaned up beautifully and o-rings look mint
    New rear wheel bearing
    Drained brakes and clutch
    Tested concrete stability directly below center stand
    Going to pick up new valve bolts and fluids. Trying to find new brake pads too but finding conflicting information when searching (online and via phone); enough that I will be purchasing from a physical location that I can stand in line to return if necessary.
  19. motorn
    motorn New Member
    Mb,Canada
    Put a Saddleman seat kit on my 1200. Very nice product at an affordable price. Installed led lights in my Givi V35 SADDLEBAGS. New Michelin rubber going on when I take the bike in for the recall. I'm looking forward to spring!
  20. atx
    atx New Member
    Got the carbs back on the 86 and was able to run it for more than 30 seconds without fearing that it would burst into flames. Hooray no fuel leaks. Still need a few more parts before i can take it for a spin, but it is so close i can taste it.
    https://youtu.be/Ko19eiZwarw
    [video=youtube;Ko19eiZwarw]https://www.youtube.com/watch?v=Ko19eiZwarw[/video]
