what do you use to clean the rims?
Discussion in 'Mechanics Garage' started by FrankoQ, May 15, 2008.
  1. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    That's how I do it, except for the wax part.
  2. Jimtt
    Jimtt New Member
    Chicago area
    I clean wheels all the time, if you don't then stronger stuff is needed. There are a lot of good ideas listed above. I am a STRONG believer in keeping a motorcylce clean; when I am on an extended trip I clean adjust and lude every morning. The process often uncovers problems you would not notice if your bike is dirty, cleaning involves looking at lots of parts closely.
  3. maddog
    maddog New Member
    Idaho
    Apt. dweller here, so I take the bike to the self-service car wash. Spray the wheels with Simple Green/water mixture, then use low power spray wash and rinse cycles.
    Between washes, I'll wipe down with wd-40 when cleaning/lubing chain.
    Never bother waxing, as after more than 80,000 miles, my wheels are scarred enough from all the tire changes.
    Used to buy specialized wheel cleaners, but now figure it's a waste of money, as S G does a decent job for not so much coin.
  4. 2ndVFR
    2ndVFR New Member
    San Jose, CA
    I use the Gojo hand cleaner. Cheap and works great. As good as WD-40 but a fraction of the cost without the oily residue from the WD-40.
  5. betarace
    betarace New Member
    Middleburg, VA
    wheel wax!
    .:: WheelWax ::.
    take your time, do it right and from then on cleaning wheels is a hose spray away. wax-em once a year and you are good to go.
  6. bat-stang
    bat-stang New Member
    H-Town Texas
    Meguiar's car wash. In between washes, I wipe down with WD-40. As stated above, harsh stuff isn't good for painted surfaces--wheel surfaces included. Some stuff will remove the shine from paint...
  7. 34468 Randy
    Usually WD40. Gets the chain lube gunk off really well. McGuire's has a metal past polish that works well as well. Found a new product called Tirox Chain cleaner. It works the best so far but is pricey. I suspect kerosene probably works as good as anything to get the oils and greases off. As far as the brake dust, I wash my bike often enough that it is never an issue
  8. NorcalBoy
    I use mass airflow sensor cleaner on a rag, followed by Honda polish.....damn, this is an old ass thread, lol.
  9. Kobe Diesel
    Kobe Diesel New Member
    CT
    Palmolive soap and water. It's cheap and does as good a job as any other crap on the market.
  10. TOE CUTTER
    After powder coating the wheels not much sticks to them, very easy to clean, worth it just for that.
  11. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    When I first got the bike I took the rear wheel off, sprayed down and cleaned with simple green for quite a while to get all the PO's lack of maintenance off my wheel. Then I let it dry and waxed it up real nice. A week later there was a ton of chain grease and other various road shit stuck to my wheel again, just as bad as it was before. :mad::mad::mad:
    Since then I use silicone spray on a rag to wipe down with and clean, and another clean rag to wipe off the excess silicone and leave a nice shine. Leaves a think film of silicone on the wheels that makes getting stuff off later a very quick and easy process. :party2:
  12. tinkerinWstuff
    carb cleaner on a rag cleans my white wheels
  13. Joey_Dude
    Joey_Dude Member
    North Georgia
    WD-40 is also a great cleaner.
  14. 34468 Randy
    I used to try centrifugal force but they kept throwing me in jail!
  15. 750nick
    750nick New Member
    There is a product called GreaseAid in a purple spray bottle that removes grease and brake dust almost immediately. It has never harmed anything on my bike either. I use a teethbrush for the nooks and a dish sponge for the rest. Works like magic and only costs a couple bucks at Home Depot. A coat of wax helps keep the dust from sticking too.
  16. Arcey
    Arcey New Member
    MeGuiars car soap and WD-40 for the though dirt , works wonder and is very soft on the rims and bike paint . Do not use dish soap if you have wax the bike it will most likely take it off .
  17. ridervfr
    Used WD-40 to practically clean entire motorcycle. Pledge works kinda nice, spray it on a paper towel and clean the rim that way too. Works as a decent cleaner protector on the petrol tank as well.
  18. madduxca
    madduxca New Member
    Navarre Beach, FL
    degreasser mixed 50/50 with water and a preasure washer will make it look brand new. actually i did the swingarm that way too. looks awsome. just dont let it sit for over 30 seconds
