what goes where?
Discussion in 'Mechanics Garage' started by michelle@az, Sep 3, 2009.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    You have won most of the battle.
    The hardest thing for an engine to do is idle.
    If it idles and revs up cleanly, and when you turn the front wheel lock to lock the idle does not increase or hang up you're good.
    After a few rides if you wanted to - you could wait until it cools down and remove the spark plugs and check the color just to see if they all look consistent which means they are all running well.
    Considering some of your posts you may want to have a good bike mechanic check the idle for you .
    DO NOT just let anyone mess around with them. They could be adjusting the mixture and think it is the idle. If you paid to get them rebuilt by someone that knew what they were doing, then don't let anyone mess up what you have so far.
  2. michelle@az
    michelle@az New Member
    Northern AZ
    i just rode around the block, seemed to idle and rev ok all the way around. didn't check it with the wheel turned fully, will do that tomorrow. don't dare ride to much - as i need new tires and i should probably register it :p more so the tires.
    i dunno about pulling the plugs - that looked difficult with the carbs off, looks very difficult with it all assembled, lol
  3. crustyrider
    crustyrider New Member
    North Country, New York
    you definately have balls sister......not to many folks will attempt what you are with out knowing anything.. and get it right..... good job.
  4. michelle@az
    Northern AZ
    except you guys that know what you are doing have to deal with tons of stupid questions from me ;)
  5. Knife
    Knife Member
    Downingtown, PA 19335
    I was pleased to see this post was moto related. From the title, I thought it was a misdirected question that was meant for the "Virgins on Their Honeymoon" forum.
  6. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    you wont know untill you ask :thumbsup:
  7. squirrelman
    YOU cheeky monkey!!!:bootyshake2:
