What kind of gas do you use?
Discussion in 'General VFR Discussions' started by dlman, Apr 2, 2007.
  1. NorcalBoy
    I disagree with you, I was involved with the fuel industry for 10 years and have first hand experience. Go ahead and run lower grade gas, it's all up to you, but your argument isn't exactly factually complete.
    #81
  2. derstuka
    San Diego, CA
    I think you have your facts reversed senor. For most of the crops in the US to make ethanol they use corn, in Brazil, they use sugar cane (sugar cane has an advantage over corn based because it has a higher energy density and plus is a more powerful and efficient fuel to use), it can also be made from wheat. read on....
    "E85 Ethanol Flex Fuel Explained
    Ethanol is an alcohol-based fuel made by fermenting and distilling starch crops, corn mostly. Only a relative handful of renewable energy companies produce it, but virtually all the ethanol they generate comes from renewable crops grown on American farms. One acre of corn can be processed into about 330 gallons of combustible ethanol.
    Proponents argue that mixing 85 parts ethanol with 15 parts gasoline to create E85 ethanol fuel helps stretch the earth's supply of oil, which is finite. Supporters, such as the Renewable Fuels Association, say E85 ethanol fuel expands the market for U.S. crops and creates jobs in agriculture and refining. By reducing oil imports, backers argue, ethanol eases the nation's trade imbalance and cuts down on the tax dollars and military resources needed to keep foreign oil flowing. "
    Methanol can be used as as an antifreeze in fuel. Methanol can be made from fossil fuel, animal waste, the garbage you throw away and several other methods. One problem with alcohols is that they are corrosive to certain metal/materials, and if your engine is not designed for it, it can reek havoc.
    One cool feature of some alcohol fuels is that when they burn they create a "cooling effect" and reduce the temp of the next intake charge.
    #82
  3. Spike
    Spike New Member
    Have you seen the new Honda FCX Clarity availible for lease now in SoCal? Hydrogen powered and availible to anyone (albeit anyone, who lives in the right area, and is willing to pay $600 a month to lease a car :smile: )
    #83
  4. 34468 Randy
    Derstuka. You're probably right and I am maybe a bit dyslesic but at my age W.T.H.. I probably spelled it wrong too. But I think we all should agree to read the manual and do what the highly paid engineers who designed these wonderful machines tell us to do and what to burn. I have always been anazed at how many back yard mechanics are out there who know more than the designers and engineers. Some may but.....I'm outta here. it's 10 degrees C out there so I am going fro a ride. Getting a modulating front light put on. Say that would make another good thread.
    #84
  5. destrux
    destrux New Member
    I've never heard of higher grade fuels causing any sort of valve or engine problems. I run 89 in my VFR because it sits alot, and I've heard octance decreases as the fuel sits, especially in non-sealed or plastic containers (I don't know if there is truth to that or not, but my dirtbikes will ping on the first ride in the springtime if I don't put fresh 93 in them, so I believe it). However... in my car (300hp turbocharged 4 cylinder mitsubishi) I run 93 all the time, along with 50% methanol/water injection (injected at 330cc/min above 2psi of boost pressure). With the methanol flowing my approximate fuel octane is 96. I have 198,000 miles on the engine (It's been modified in it's current configuration for the past 110K) and have never had to replace any internal parts, and I really beat on the car, alot.
    #85
  6. elf800
    elf800 Banned
    dallas
    the gas at the gas station has worked fine for me so far...
    #86
  7. PuCaudata
    PuCaudata New Member
    Great Falls, Montana
    I usually run 91 octane (91 is the highest offered in Montana...higher elevation). I have switched back and forth between 88 and 91. I think the 91 idles and runs smoother in the motor. But, I think the 88 has more power. Just an observation...
    I hear from some of my motorhead buddies that the lower flash point of lower octane fuel actually makes it burn easier, therefore, giving more power and better fuel economy. But, in the days of higher compression motors higher octane is needed to prevent pre-ignition.
    #87
  8. Sandalwood
    Sandalwood New Member
    Chattanooga, TN
    Here is something that I haven't seen in this thread already.
    I'm a car guy as well as a bike guy, and I have learned that there is a website that is a coordinated effort by some top car manufacturers (BMW, General Motors, Honda, Toyota, Volkswagen and Audi) that notes what fuel retailers they recommend. I have no reason to doubt that their fuel quality recommendations are directly applicable to the fine V4 as well. Top Tier Gasoline
    Here is their current list:
    QuikTrip
    Chevron
    Texaco
    MFA Oil Co.
    Conoco
    Phillips 66
    76
    Entec Stations
    Shell
    The Somerset Refinery, Inc.
    Kwik Trip / Kwik Star
    Aloha Petroleum
    Tri-Par Oil Co.
    Turkey Hill Minit Markets
    Mileage Stations
    Chevron Canada
    Shell Canada
    Petro-Canada
    Sunoco Canada
    Pretty much all the big names, but conspicuously missing are Exxon and Mobil. Hmm!
    #88
  9. Knife
    Knife Member
    Downingtown, PA 19335
    Uh-h-h-h, gas? I often have gas, but I don't know what octane it is or what I can use it for. Will it work in my VFR?
    #89
  10. Sandalwood
    Chattanooga, TN
    I would think a propane kit should work for making power from your methane surplus. :smile:
    #90
  11. Wheatie
    Wheatie New Member
    Huntington Beach, Calif
    I used Union 76 91 octane for years until gas prices skyrocketed last summer, at which time I started questioning the validity of high octane gas for my '86... soooo, I tried 87. Found no difference in permformance across the board and now use Arco if I'm REALLY feelin' cheap, then Chevron or Union 76 .. ...
    #91
  12. yoda6669
    yoda6669 New Member
    Georgetown, TX
    yodasmile I use the cheapest brand available except CITCO(I don't want to fund Chavez's Army) and 7-11. Regular Unleaded 87 octanes. I also add a Chevron Techron fuel system cleaner every oil change. No problems so far.
    #92
  13. Spike
    Spike New Member
    I just use regular, usually Costco or Safeway, since they tend to be the cheapest. But I have been known to go elsewhere if the need arises. Never any fuel problems on bikes or cars, and that includes a 238,000 mile Camry.
    #93
  14. Mikonovich
    Mikonovich New Member
    Ventura, CA
    Learned the hard way last week that cheap gas can cause problems. Running Chevron 87 in my Toyota Tacoma, never had a problem. Had a road trip last week and put Rebel 87 in. 150 miles later the truck wont idle. Quits if there is no throttle input. Put Chevron 89 in to try to make up for the bad stuff. Everything fine 150 miles later. Half tank of each. Couldn't believe it. Its only name brand for me from now on. VFR? '07 gets the Chevron 91 every time. After reading here, though, I think I may switch to 89 and see what happens.
    Mike
    #94
  15. 34468 Randy
    Mike,
    What I believe you probably ran into here is gasoline that may be on the stale side. Even the top refiner's gasolines will cause you problems if it is pumped out of tanks that do not have a higher turnover of gasoline. I used to burn "Silver" gasoline ( unsure of the octain but it was mid range). I have since switched to the lowest oactain available and have noticed no difference in performance or mileage in the slightest. What I do try to ensure though is that I obtain my fuel from a busy station. This guarantees fresh fuel. Basically I am following the instructions set out in the owner's manual.
    #95
  16. RVFR
    Even thou gas prices have gone up and down like a Yo-Yo I'm still running on Chevron super duper and yes it makes a difference.
    #96
  17. Knife
    Knife Member
    My understanding has always been that if you burn a grade of gasoline with a higher octane rating than called for by the motorcycle or automobile manufacturer, it's just a waste of money, and that there is no performance gain of any kind realized. I'm reading contradictory statements here. Is there a definitive answer to this?
    #97
  18. Carnage
    Carnage New Member
    Terrell, TX
    I only put 87 in my '07. I have tried premium but I can not tell a difference in how the bike acts and my mileage goes down quite a bit for some reason. If there is not advantage(there is a disadvantage for me) I see no need to spend more money.
    #98
  19. Spike
    Spike New Member
    all the things I have ever read all say that it is far more important to go to a busy station, that has turn over of the tanks than to go with one particular brand. If you live in the northeast, it is all going thru the same pipeline anyway from the refineries int he south. It is all the same gas. They put x number of gallons in, and they get x number of gallons out, but not necessarily the same exact gas they put in. Now the distributer may add their own additive package, but the underlying gas is the same. Go with any of the major names, and go with a busy station, that is all you need to do.
    #99
  20. derstuka
    San Diego, CA
    As Randy was talking about somewhat, you probably had a bad batch of gas that had water in it. Throw some dry gas in her if that happens again.
    As spike said, busy gas stations are usually a safe bet, as they turn over gas and it doesn't sit. I do not like ARCO gas though.....as my old truck use to get 20+ miles per gallon less on tankfull. I tested that theory many a time....always was 20+ less than other well known brands.
    I do believe that there is/can be a difference in quality regarding brands of gasoline though. Just like oil is of varying quality. Depends of methods of refinement for one....
