Why is the bike so heavy?
Discussion in '8th Generation 2014-Present' started by GatorGreg, Sep 16, 2016.
  1. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I feel like I replied to this yesterday? Was this posted in multiple forums or something?
    #61
  2. Gator
    Gator Member
    Drinking and posting? lol
    #62
  3. duccmann
    Well Mr Pete, if ya got ta ask--
    Your there bro
    #63
  4. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    that is a possibility
    #64
  5. NorcalBoy
    Not even Scott Redding.......
    #65
  6. sunofwolf
    sunofwolf New Member
    single carbon muffler lost 19pds, light weight battery 3 pounds, 520 chain 3pds. 24 pds right there. the frame looks really heavy but super strong-it is a heavy beast
    #66
  7. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Because it is built to last!
    #67
  8. Bubba Utah
    Bubba Utah Member
    Utah
    Hell, no! Not in age, weight and riding.
    #68
  9. fink
    fink Member
    How long does a 520 chain last compared to a 525 or 530 one then?
    #69
  10. Mohawk
    Mohawk New Member
    Bristol
    Light & Last do NOT go together, so that's the wrong question :)
    That said a quality x-ring 520 on quality sprockets will last just as long as a 530, most chains wear out one spot long before the rest. Chain life is more a function of use & maintenance & less of the chain size if equal quality !
    YMMV literally !:)
    #70
  11. fink
    fink Member
    I know that but the question still hasn't been answered. How many miles?
    The difference between a 520 and 530 chain is 0.5kg.
    #71
  12. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I routinely get over 25k out of my did 520 kits. Good enough for me :)
    Sent from my Nexus 6 using Tapatalk
    #72
  13. Gator
    Gator Member
    I know a lot of guys that are tracking 1000cc bikes with 15k and more miles. I have 10k on a DID 520 and AFAM sprockets on my track bike CBR 1000. Good maintenance and quality parts and they last just as long.
    #73
  14. fatshoutybloke
    fatshoutybloke New Member
    Essex, UK
    My VFR's a week or two shy of two years old and the original 520 chain & sprox are fine after 18000 miles.
    #74
  15. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I don't believe in maintenance for O-ring chains and I still get 25,000 plus miles lol. The O-rings are designed to keep the oil inside the chain and the contaminants out. No point in lubing the outside, it just attracts dirt. I still keep the proper tension, but I don't lube/clean it.
    #75
  16. Mohawk
    Mohawk New Member
    Bristol
    Well said CR, I do the same but do have to clean it periodicly, as we have rain quite often in the UK :) But I did my EURO Tour in July 2500 miles on my 525 conversion with alloy rear sprocket & top of the range RK X-ring chain, never had to adjust the chain. Temps were in the mid 30's for most of it. That chain has done about 12K miles & is still good, its had 3 alloy rear sprockets in that time. They are quite worn by about 4-5K miles. I'll be changing the front sprocket this winter.
    Have a read here http://www.rogueracing.org/gearing.htm see the 530-V-520 section, 15K racing miles on an S1000RR on a 520 says it all.
    #76
  17. NorcalBoy
    How many miles on your VFR and how many times have you changed the chain and sprockets?
    #77
  18. Gator
    Gator Member
    That article is from a friend of mine that owns that site and I got him to be a member here though he does not visit often. He is a plethora of info. I agree about the chain being sealed but I think its still a good idea to keep it and the sprockets clean as a lot of the wear is on the sprockets themselves. Add a little ground up sand, dirt road grimes spinning at high rpm's and the sprockets and chain exterior does get a lot more abuse.
    #78
  19. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I find that the chain needs a lot less cleaning, if you don't lube it, since there is no lube to attract dirt and sand. Also the chain doesn't seem to want any lube until it's at the end of its lifespan, as in all the internal oil has made its way out and the orings start drying up. At that point, it's pretty much over anyways and the lube is just a spent time bandaid. I'm sure I could get over 30k like this with a 530 chain, but I'd rather have the extra half a hp or so lol.
    #79
  20. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I definitely agree keeping the chain clean is a good thing though.
    #80
