will more teeth actually help.
Discussion in 'General VFR Discussions' started by GoForARide, Nov 30, 2009.
  1. GoForARide
    GoForARide Banned
    my chain and sprokets are on their way out. iv got to spend the money anyway.
  2. Knife
    Knife Member
    Downingtown, PA 19335
    Go4: For an inexpensive fix, simply grind one of the teeth off the front sprocket. Voila!
  3. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Yes, a torch is hotter than a boiling water, but it's the water that catalyzes the reaction and accepts the electrons from the metal in the sprocket. When electrons are released from the metal, the metal becomes stronger due to the ionic bond between the molecules.
  4. Interceptor1
    Interceptor1 New Member
    Quebec
    I went +2 on the rear with a SpeedoHealer on my '06 and I would never go back to stock. :smile:
    I don't needs to go over 125 mph on public highway anyway. :biggrin:
  5. GoForARide
    GoForARide Banned
    does anyone else concur?
  6. Joey_Dude
    Joey_Dude Member
    North Georgia
    Yes this is physics 101. If you want to get even more life out of your chain you might want to mosey on over to your local particle accelerator lab and bombard the chain with boson particles.
  7. havcar
    havcar New Member
    Denver CO
    Shame on me...should've known better!
  8. GoForARide
    GoForARide Banned
    Does anyone else do it?
  9. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Yes, I concur. I went -1 front, +2 rear and the highway rpm's were just too high so I dropped the front back to stock and left the +2 on the rear. 75mph in 6th gear is now a little less than 6K rpm, with the -1 up front it was closer to 6500 rpm if I remember correctly. I haven't noticed any change in mpg. This is on my 5th gen.
    I don't boil my sprockets although I will steam them, or bbq them if I have some sauce in the kitchen.
  10. captb
    captb New Member
    I shipped mine to Cern, they ran it thru the Hadron Collider, seems better now.:biggrin:
  11. vfourbear
    vfourbear New Member
    Cincinnati
    AHHHHHHGGGGGGGHHHH
    just stop it.
  12. GoForARide
    GoForARide Banned
    read somewhere to boil it in oil. what do you think of that?
  13. runnerhiker
    runnerhiker New Member
    Beaumont, TX
    I think Go4 is taking us for a ride.
  14. GoForARide
    GoForARide Banned
    dude, what the heck is your problem.
  15. runnerhiker
    Beaumont, TX
    Whatever I have is not as bad as what you have.
  16. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Check this site out for gearing changes: Gearing Commander: Motorcycle Gearing Ratio Sprocket RPM Speed Chain Calculator
    I dont know if it has older VFR's or not but I know 6th gens are on there. Larger in the front or smaller in the back will lower RPM's and thus possibly increase MPG. The change will likely not be too much, but noticible over the long term. It will make your speedo read incorrectly, but its possible that your speedo is off anyway.
    As far as tempering or annealing your sprockets... that kinda stuff SHOULD already be done at the factory. Chances of you increasing the strength more than the way it comes from the factory are slim to none. Don't worry about it.
  17. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    I do "it" every once in a while. Depends on if my girl's on her period.
    Have you checked to see if you're missing any chromosomes yet? I'm sure you're missing at least 2 and maybe part of a third.
  18. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    As long as it's Canola oil. They use that for tempering.
    Going one down on the front from factory makes the chain take a small radius for the turn. Puts more stress on the links which = shorter life. How much shorter????
  19. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Only those who believe he's that stupid. If you know he's messing around, it's funny.
  20. havcar
    havcar New Member
    Denver CO
    Untill all of his duping gets borish, at which point his humor begins to make him look like he's just another insufferable airhorn.
