Will not take throttle
Discussion in 'Mechanics Garage' started by REDROD, Aug 1, 2011.
  1. REDROD
    REDROD New Member
    when i start to turn what i thought was pilot screw gas starts to drip out the bowl drain!
    You seriously need to read the service manual before you screw something up.
    :behindsofa:
  3. REDROD
    REDROD New Member
    thanks for the advise! Reading the manual can't hurt!
    I didn't look closely at the picture from tinker but it appears that he is illustrating a pre-93 bike! Since the pilot screw on my 95 is set from the factory and had not been removed i assume no adjustment is needed!
    I was just so excited that finally might have an answer i over looked the obvious!
    Any input that you might have will be appreciated!
    Thanks again!
  4. kennybobby
    kennybobby New Member
    Congrats--you found the steel drain screw...
    And yes you are right the illustration is not a 4th gen carb.
    The brass pilot screw has a "D" shaped head that requires a special tool, and is accessed from below the carb and not from the side--it is invisible from the side since it is recessed in a down tube located between the notch of the float bowl cover and the insulator band.
    When the carbs are off i usually use a dremel cutoff wheel to cut a thin slot in the pilot screw head so a flat blade screwdriver can be used for adjustment.
  5. squirrelman
    No carb cleaning is complete without removal of the idle mixture screw and a blow-through of the hole with carb cleaner spray and compressed air.
    The special tool needed for gen 4s comes in a Dynojet/K&N jetkit or can be bought from Motion Pro.
  6. REDROD
    REDROD New Member
    squirrel,
    am i correct in assuming that the idle mixture screw is the same as the starting enrichment valve in the service manual?
  7. tinkerinWstuff
  8. REDROD
    REDROD New Member
    TINKER
    I APPRECIATE THE ILLUSTRATION BUT MY BIKE IS 4th GEN (95 VFR)
  9. tinkerinWstuff
    fuck me running. didn't realize they would have changed that.
    egg, face, me
  10. tinkerinWstuff
    get a 12pack of beer and a neighbor qualified to help you out
  11. squirrelman
    No, not at all !
    Idle screw is located on the underside of carb, brass-colored, surrounded by a circle of carb metal as described by K-B. ^^^^^
  12. REDROD
    REDROD New Member
    i think you have hit on the problem! I have noticed that when i drink beer i start getting smarter
  13. anarchy13
    anarchy13 New Member
    Germany
    1/4 throttle, No Respose
    This is some good information here!!! Did you guys ever find the problem for this issue? I have a similar problem but I know my choke works cause the bike only starts with the chocke on. Stars fine, idles fine, revs fine, but as soon as i hit the road after 1/4 turn of the throttle she just starts popping and wont go any faster and the more i turn the throttle the more she bogs down and becomes unresponsive!!!
