yellow wire & regulator hot
Discussion in '6th Generation 2002-2013' started by 913, May 25, 2009.
  1. 913
    913 New Member
    I smelt something burning when i observe
    1. the regulator was hot
    2. the yellow wire from regulator changes colour to brown
    3. the connector for the yellow wire swells funny and wire connectors brown
    4. 30 amp fuse melts
    It is a VFR800 Vtec 2005
    Can any body help me?
  2. Dudealicious
    Dudealicious New Member
    Smoggy but always sunny, LA
    that is what happens when your stator is in the process of failing
    somewhat easy repair. will cost about $200 in parts.
    not that common on a 4 year old bike though.
    following the stator replacement, check your R/R first!
    good luck
