yet another project
Discussion in '1st & 2nd Generation 1983-1989' started by matt1986vf500f, Apr 12, 2009.
  1. deepdish
    deepdish Banned
    man put harley forks on it then you can say its an every manufacturer bike.......
  2. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    HMM.......well whats the best way to say this....NO
  3. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Already tried a set of '05 600RR forks I had laying around, they're too short(same as 1000RR).
    I know of another guy who put 929/954 forks on an 86 750 track bike, and he's having problems with the tire rubbing the cylinder head under hard braking... :ninja:
    Rear tire is a garbage Cheng Shin 190, it will be swapped out for a 180 Pirelli Diablo soon. The 190 is too wide. I have the chain lined up correctly using a VF500 hub in the 900RR wheel and there will be a very thin spacer to separate the hub from the swingarm. I also have to cut down the sprocket studs and use smaller nuts to hold the sprocket in order to clear the arm.
    The swingarm will be braced, not just for the tire, but also because I might be cutting a section of it out on the front right side to accomdate the up pipe for the dual carbon exhaust. :cool:
  4. supertex
    supertex New Member
    Matt, what tail is that, and is the subframe modified? It looks like it's bolted to the stock location.
  5. matt1986vf500f
    its just sitting on there right now the sub frame is unmodified but the bolt holes are pretty damn close, its a 04 gixxer tail that came off the track bike :thumbsup:
  6. NorcalBoy
    I believe that is off of a GSXR 7fitty, holla!
  7. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Makes it look kinda like a cafe-fighter the way it's sitting there!
  8. supertex
    supertex New Member
    Have you checked the dimensions at all? Who cares what other people say. If it fits, do it.
  9. matt1986vf500f
    so far its lookin good the 800 motor is the same width as 750 now i need one! :thumbsup:
  10. Joey_Dude
    Joey_Dude Member
    North Georgia
    Didn't they make a 1000 cc version for that year? Just a thought it could be easier since they should be compatible. With swapping a different engine from a different generation you might have to swap the tank as well because they are tightly integrated with each other.
    And while you're at it might as well replace the dash with a 5th gen dash so you can get the tach/speedo/gas guage. Oh and while you're at it go ahead and get 5th gen plastics to make it all fit. oh, and get a single swing arm.... :thumbsup:
  11. matt1986vf500f
    no they didnt make the 1000r that year and im sure it might fit but i want a fuel injected motor and something that will respond well to mods and so far keeping with the v-4 thats the 5th gen engine, ( oh lets not forget the that lovely sound to) the tank will require some work to fit the fuel pump in it but! these bikes already came with a fuel pump so i maybe able to make that work and it will be getting the single sided swing arm as well but the fairings are gone be wild :thumbsup:
  12. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    I've found that the VTEC and 5th gen tank would be really easy to fit to the 1st & 2nd gen frames. They don't look right with stock bodywork, but since you're changing that up anyway...
    I have a nice pearl white one here with an easy dent on one side, yours for $50 plus shipping.
  13. matt1986vf500f
    hmm... how does it look on the bike?? well i need to start selling a few things of so the build can go forward:frown: the motor that came out of the bike is for sale, any takers? the wheels are also up for sale and a few other items that im not going to reuse. :thumbsup:
  14. crustyrider
    crustyrider New Member
    North Country, New York
    how about the RR
  15. matt1986vf500f
    are they the same this one is a 87?
  16. matt1986vf500f
    well its finally tore down, i was thinking of mybe powder coating it, like dull bronze?? but now its time for me to get some parts in to make it come together, yea!! :thumbsup:
  17. Joey_Dude
    Joey_Dude Member
    North Georgia
    Just had a thought, you might want to check out motorcycle junkyards and see if they have a 5th gen motor and ask to look at it. Then you bring your frame and see if the mounting bolts line up or see if they can be improvised. That way you can tell for sure if a 5th gen motor is compatible instead of crossing your fingers.
  18. matt1986vf500f
    yea theres the problem finding a junkyard that will return my phone calls :confused: but at best at all the photos that ive been looking at of the 5th gen motor i will be lucky to have 4 holes line up im going to have to machine motor mounts for it :thumbsup:
  19. supertex
    supertex New Member
    How are you going to fab mounts? I've heard more than one person say this and was wondering what material and design might be strong enough.
  20. matt1986vf500f
    Aluminum, Titanium..etc... i now have access to a tig welder. right now im stuck untill i get a motor, but first i need to start cleaning the frame and get it prepped for the swap
