Where to buy carb rebuild kits for 86 vfr750?
Discussion in 'Mechanics Garage' started by jby, Mar 6, 2012.
  1. jby
    jby New Member
    anyone know the best place? google search didn't do much good. Are they the same carbs as the 700F?
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Do you want aftermarket or Honda OEM?
  3. jby
    jby New Member
    I'm not particular. I just don't want to spend over $200 if possible.
  4. jby
    jby New Member
    the carbs on this bike look like a royal pain. I did my cbr a few months ago just fine and I have little experience. I am just feeling ambitious and don't want to spend the $600 in LA to have honda do it.
  5. Railguy
    Railguy New Member
    New Mexico
  6. Pops
    Pops New Member
    Stephenson, VA
  7. jby
    jby New Member
    Fantastic! Thanks guys. you rule.
  8. jby
    jby New Member
    I've never done the carbs on this bike. is there anything I should watch out for while removing them or will my shop manual guide me through it well enough (I've done carbs on other bikes).
  9. jby
    jby New Member
    I found some great threads. I'll upload some pics when i get it apart.
  10. Pops
    Pops New Member
    Stephenson, VA
    Here is the definitive carb cleaning thread, compliments of TOE CUTTER.
    http://vfrworld.com/forums/mechanics-garage/22449-cleaning-carbs.html
    As a rule of thumb, DO NOT seperate the carbs from the aluminum manifold. The plastic runners that carry gas between the carbs are extremely fragile to start with, and only get more brittle with age.
  11. Dukiedook
    Kansas City, USA
    +1 ^^^^^^.
  12. jby
    jby New Member
    Is cleaning the jets good enough or should I replace them with new ones? I was surprised how easily the carbs came off with the filter plate. Almost too easy. I feel I got lucky.
    I think one of my gaskets is a little leaky and now that I've pulled them apart I'm afraid the rest of them tore. So I will at least need float bowl gaskets and float needles. Any advice?
  13. squirrelman
    No need to replace jets IF they are clean !
    Do a search here for the float bowl O-ring set of 4 from K&L Supply @ about $40. I forgot the kit number.....
    High-mileage vaccum slide needles need inspection and replacement if wear is seen, but other parts only need replacement if they are leaking or damaged.
  14. Dukiedook
    Kansas City, USA
    Odds are your needles and jets are perfectly fine and do not need replacing (unless you bent the needle somehow), plus people have had problems with the needles on Keyster kits on the CB750's if Keyster is what you are looking to buy.
    You really just probably need to clean out the jets and float needle basket and the only thing you need to change are the o-rings- a 041 Viton o-ring will more than work for the float bowl gasket, you should be able to match up the other o-ring gaskets at you local o-ring shop save the air rail gasket- the SAE equivalent will not work there- you will need the metric o-ring there.
    Jesus man, did you not listen- WE TOLD YOU NOT TO SEPARATE THE CAB BODIES FROM THE MANIFOLD UNLESS YOU ABSOLUTELY HAD TO.
    You just made the job 2000% tougher- good luck and may the gods help you.
  15. jby
    jby New Member
    You just made the job 2000% tougher- good luck and may the gods help you.[/QUOTE]
    They are still connected to the manifold. I read all those caps on every other thread. I don't think I'll have a problem. I appreciate the help sincerely though, guys. What would I do without people like Dookiedook?
  16. squirrelman
    Without Dookie you'd be down on your knees looking for springs under your workbench.
  17. jby
    jby New Member
    Anyone know where to buy the rubber engine boots? mine work but are chewed up.
  18. jby
    jby New Member
    nevermind I found them. I need to learn to search before I open my internet mouth...
