Gen 8 install Garmin Zumo 595LM and usb charger using relay/switched power
Discussion in 'Mechanics Garage' started by Ronsk, May 2, 2020.
  1. Ronsk
    Ronsk New Member
    Sorrento, Victoria, Australia.
    Hello, I have a 2015 Gen 8 VRF800 that I am going to install a Garmin Zumo 595LM on. The mounting will be using a RAM ball mount on the triple clamp. I have a 5 pin 30/40 amp replay that I want to use so that I have switched power to the GPS. Also I have a USB charger/volt meter (the rocker switch look type) to install on the relay. My question is has anyone done this before and what problems did you encounter, what should I be careful of? Also I was thinking of using the number plate light as the trigger for the relay? has anyone done this and which wire is it? Have attached a picture of the usb charger (it have a volt meter in the middle) and the location I am going to mount it on the bike. It does involve cutting the black plastic fairing piece Thanks. USB 01.jpg USB 02.jpg USB location.jpeg
  2. fink
    fink Member
  3. Ronsk
    Ronsk New Member
    That is interesting. I have wired in a relay and used the accessory plug under the seat as the trigger as a temporary measure. After looking at all the options I have ordered a Fuzeblock FZ-1 and DJ7045F-2.2 socket plug. This will tidy up all the wiring connections. I also have a USB charger on the bars with a quadlock for the phone. so there is a bit of extra wiring......
