Raising and stiffening VF500F2 rear?
Discussion in '1st & 2nd Generation 1983-1989' started by Norse, Feb 3, 2016.
  1. Norse
    Norse New Member
    Denmark
    Hey.
    One of the things I would like to do to my new VF500F2 is raising the tail and making the rear suspension a bit stiffer.
    I remember reading somewhere that there is a simple and cheap way to do this, but I can't seem to find it ATM.
    Any advise would be appreciated.
    The "Good/Fast/Cheap" triangle... you can only pick 2.
    If you want something good and fast?... it wont be cheap. And so on...
    The fast and cheap answer is to add more air pre-load to the rear shock (Pretty sure the recommended range is 17-43 PSI). It will raise the rear and "stiffen" the suspension.
    But the "non-good" aspect is that it will highlight the shortcomings (under-sprung and over-damped) of an already pretty lame shock when new, that is now 30 years old.
  3. c3_dk
    c3_dk New Member
    Velkommen til VFR World :- )
  4. FastCletus
    FastCletus New Member
    Napa Valley USA
    I have the same question. After reading the service manual I don't think you can raise it. Maybe tuning up the rear shock is possible to get a higher rear, but not 100% certain. I am 200lbs and i feel like my bike is bottoming out on some bumps. I have the rear shock set at 20 psi which is 1lb lower than what the service manual says is max, so I cant think adding 1 more lb is going to make any difference. I bought the bike for $300 hard to justify putting $400 in a new shock
  5. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Try to find an alternative second hand shock. The OEM wasn't great in the first place so it's almost certainly past its sell by date by now.
    In the UK we have Hagon that make cheapish aftermarket. They come up on Ebay from time to time. They work OK.
  6. FastCletus
    Napa Valley USA
    found a Hagon dealer here in the states but they are still in the $400 range
  8. FastCletus
    Napa Valley USA
    I bought another used one locally and going to see if it solves the problem. If it doesn't then I am only out $30. Will start looking for a rebuild one or save some $$ and buy a new one
    Sent from my iPad using Tapatalk
  9. FastCletus
    Napa Valley USA
    Love the mod you did. I wish my welding skills were that good!
