Sixth gen died
Discussion in 'Mechanics Garage' started by RobVG, Feb 10, 2018.
  1. skimad4x4
    France
    French Alps & London
    And we have another example of why this thread should be recommended reading for anyone owning a 5th/6th gen>>
    http://vfrworld.com/threads/how-to-fix-common-regulator-stator-failures.39277/
    Ok if its all fixed now, please also consider adding a cheapo digital voltmeter - you can pick them up for buttons on Tbay - just choose the type which shows volts as a number - not a line of flashing lights. A voltmeter won't prevent a repeat, but it will at least give you a chance to spot if there are charging system issues developing and give you a chance to head for some place safe before whatever energy is left in the battery is drained and you end up stranded.
    SkiMad
  2. RobVG
    RobVG Member
    White Rock BC
    Thanks man. I forgot to add something. The stator checked out fine on the first test but when I got around to checking it again, AC voltage at idle fluctuated between 9 and 10 V. No bueno....
  3. RobVG
    RobVG Member
    White Rock BC
    First thing I did:
  4. skimad4x4
    France
    Thanks Rob
    That's a very neat install - if they ever add in a couple of USB outlets to a voltmeter install like that it would be a best seller.
    SkiMad
    reg71 likes this.
  5. reg71
    Sikeston, MO
    Light bulb.
