  1. James Bond
    James Bond Member
    Dixie
    Nothing,
  2. 34468 Randy
    Same here. Nothing yet. But hopefully my rear tire has arrived and that will get mounted. Pulled the rear wheel off yesterday and gave it a really good cleaning with a decent rim cleaner. Makes the world of difference on these white wheels. I would do the front as well except the rotors need to be removed to give them a good cleaning and I just don't feel like that right now.
    I still have some ceramic coating for automobiles that works well at repelling water and therefore dirt. Maybe I will give that a try on the rear wheel. Very simple to apply. Maybe I should just get them re powder coated charcoal grey.
  3. duccmann
    Well so far just rode to work, it was 37 here in LA.
    What the heck
  4. scottbott
    scottbott Member
    Grantham,Lincolnshire,UK
    looked at mine ,it is all clean and shiny, it will be until the spring as I am a big girls blouse
  5. duccmann
    All righty then
    Riding a 2000 likes this.
  6. Igrok
    Igrok New Member
    rode it! It finally warmed up and with a high of 56, I couldn't resist.
    duccmann likes this.
  7. RllwJoe
    RllwJoe Member
    After November and December weather that for the most part was 10*F colder than normal, I took advantage of the almost 15* above normal temps by washing my '98,
    then I took it for a ride, not having any route in mind other than trying to avoid the road salt residue.
    I ended up pulling into the Riders Discount wearhouse parking lot.
    While there I ran into the owner, and we talked at length, and I tried to find a pair of boots that fit both my style and my feet, to no avail.
    I was tempted with this, and have started a new forum if you are interested.
    All in all, a great January day!
  8. OOTV
    OOTV Member
    The other day I replaced my FH020AA RR on my 5 gen with a Sh847. The plan is to put the Fh020AA on the 6 Gen along with the Shorai battery I got last weekend. I also replaced the chain and sprockets on the 6 Gen, with a JT Sprockets-DID chain kit from Sprocket Center. Although the sprockets looked OK, the chain was definitely in need of replacement. Tight in some spots and loose in others, the kit was a welcomed replacement. Tomorrow I'll be getting to the RR installation along with a set of Oxford heated grips. Even though it usually doesn't get too cold in So Cal, it has been in the mid 30's F and low 4o's F in the mornings when I head out on the road, I think with the gloves I have, the heated grips should work well.
    New SH847 RR
    FH020AA in comparison
    New Shorai battery
    I also bought the Shorai charger that has the multi-pin charging cable. The charger has a 'store' and a 'charge' mode. When I work from home, the bike usually just sits, so now I can keep it in store mode when it has to sit for a while.
    New chain kit...
    When replacing the front sprocket, here's a handy way of keeping the clutch slave from slowly spitting the piston out
    Almost there....
    Samuel, RllwJoe, 4corsa and 1 other person like this.
  9. OOTV
    OOTV Member
    Well, today I got to my 6 Gen RR installation. I took the FH020AA from the 5 Gen and installed it on the 6 Gen. I started about 10AM but then went to have lunch and a couple of pints at the pub with VFRWorld member Hammerdrill. That took 4 hours out of my day. Then I went back to it for a few minutes, then had dinner and then back to it after dinner. I was able to wrap up the RR install just a little past 7PM. I was planning on doing the heated grip installation too but with the "slacker" time I took, I'm had to put that on hold until later. I did pre-wire the main lead of the control unit to the front left side of the bike, so now it should be real easy to get the grips and controller wired up. All RR, wiring, connectors and mounting hardware were purchased from www.roadstercycle.com.
    The RR mounting plate...
    The RR to stator wire soldered splices... (Pre solder obviously)
    Post heat shrink...
    The RR tucked away in its little hide away...
    Samuel, duccmann, blalor and 2 others like this.
  10. duccmann
    Let me know how difficult it is Installing those heated grips, I definitely want to do that next.
    Bubba Utah likes this.
  11. CDA441
    CDA441 New Member
    Belgium
    Added a seat cowl (bought yesterday), and tankbox (from my old XF650) on the bike:
    Samuel and 4corsa like this.
  12. 4corsa
    4corsa New Member
    It's a lot more difficult and less effective than buying heated gloves!
    Sent from my Pixel 2 using Tapatalk
  13. OOTV
    OOTV Member
    Actually, not a lot of work, at least IMO and I'm really not a fan of the electric glove offerings from the electric gear manufacturers. I have good quality winter gloves that work well but could use that little bit of added warmth. I do have electric glove liners for a different pair of gloves that I like but prefer the other gloves much more.
  14. 4corsa
    4corsa New Member
    My main issue with heated grips is they only heat the palm of your hand, and it's the wind side of your hand that gets cold. I recently bought a pair of Joe Rocket Burner gloves that come with their own rechargable lithium battery, so they don't require other electric gear and wiring. They last 4 hours on the low setting, which so far, has been plently warm. And since I have 2 bikes (and have been known to sell and trade them every couple years ), I'm not constantly installing heated grips.
  15. duccmann
    Think I’ll have both the gloves and the grips.
    Rather have all bases covered since I’ll be in CO.
    Viffer J and Bubba Utah like this.
  16. RC46-SP2
    RC46-SP2 New Member
    Haven't done much to my bike for a while, if I'm honest. The wife and I are in the throes of getting ready to do a small amount of travelling, and then move into our new (to us at least) house in sunny coastal Queensland.
    Thing is, that house has the obligatory attached double garage...and a large (8m x7m) shed out the back.
    That particular shed will be getting the full man-cave treatment...and then, the VFR will be getting the full "refurb" treatment.
    In preparation, I've procured the following:
    1) 2000-model engine, supposedly with ~67,000kms on it (~half of what the current engine does). That will be compression/leak-down tested in the near future to verify it's internal condition).
    2) Injectors from that engine have been pulled, shipped off and tested/ultrasonically cleaned, sealed and returned to me.
    3) New AS3 silicon hoses and clamps to suit.
    4) New thermostat and O-rings (from Partzilla)
    5) New iridium plugs
    More bits and pieces to follow. I may even get myself a set of the headers being discussed on VFRD (and here presumably), to "replace" the ceramic-coated '99 headers on the bike currently.
    Should be a good project to keep me occupied for a bit...
  17. James Bond
    James Bond Member
    Dixie
    Agree. I've had two bikes with heated grips and they're very much over-rated. GOOD winter gloves are not over-rated....
    34468 Randy likes this.
  18. CDA441
    CDA441 New Member
    Belgium
    Ridden it, fell in love with it again :)
    Thumbs, Riding a 2000 and OOTV like this.
  19. OOTV
    OOTV Member
    Got the heated grips installed, as I said, got my preferred gloves which do well but wanted a little something extra. Don't know if/when I'll get to try them out but the install was simple enough.
    Clutch side...
    Throttle side...
    Throttle grip wire path...
    The controller...(Mounted with double sided tape)
  20. CDA441
    CDA441 New Member
    Belgium
